0 Replies Latest reply on Jul 31, 2009 2:03 PM by Jason Szeto
    [svn:fx-3.x] 8970: Slider Tick bug fix
    Jason Szeto Level 3
      Revision: 8970
      Author:   jszeto@adobe.com
      Date:     2009-07-31 14:03:33 -0700 (Fri, 31 Jul 2009)
      Log Message:
      Slider Tick bug fix
      http://bugs.adobe.com/jira/browse/SDK-15529 - Ticks arent centered properly in HSlider control
      Patch submission from Aaron Whiting:
      "Tick marks drawing code included an x-offset value to adjust the tick mark location by half of the tick line thickness. X-offset value was removed from drawing code and ticks are now centered."
      The ticks no longer need to be offset since we switched from a Sprite symbol to using the drawing API.
      QE notes: Add test case
      Doc notes: None
      Bugs: SDK-15529
      Reviewer: Jason
      Tests run: Slider
      Is noteworthy for integration: No
      Ticket Links:
      Modified Paths:
          flex/sdk/branches/3.x/frameworks/projects/framework/src/mx/controls/sliderClasses/Slider. as
