2 Replies Latest reply on Aug 1, 2009 9:48 PM by Fulvioval
    2 simple questions
    Fulvioval Level 1
      Hi friends, I'm newbie in Premiere Pro and need help with 2 questions:
      1. I put 3 photos on timeline. Can I change duration of this 3 at same time?
      2. I created an effect Ease In using keyframes. How I can save this effect to apply in other photos?
      Thanks a lot!!
        • 1. Re: 2 simple questions
          Curt Wrigley Level 4
          Thanks a lot!!
          1. Yes; if you are using ver cs4.  Select them all, right click on selection and adjust the speed/duration .  Note; if you are increasing the duration you will need to check the option to allow the timeline to ripple.
          2. Save it as a preset.  Then apply the custom preset to whatever you like.
          • 2. Re: 2 simple questions
            Fulvioval Level 1
            Thanks a lot Curt. Presets works fine! I'm using a CS3 version.
            Where I can find this option? -> "check the option to allow the timeline to ripple" Alway when I set a new duration, I need to change the timeline...
