7 Replies Latest reply on Aug 2, 2009 5:03 PM by Ramón G Castañeda
    Help! can't see CR2 thumbnails In Bridge
    jsuttonphotography
      what can I try?
      I cannot see the thumbnails in Bridge but can go into CS4 and open them up no problem
      I shoot Canon 5d Mark II
      I downloaded Camera Raw 5.3
      works fine for my regular 5D but no on the new Mark II
      any suggestions?
      thanks!
        • 1. Re: Help! can't see CR2 thumbnails In Bridge
          Ramón G Castañeda Level 4
          You need Camera Raw 5.4.
          The obsolete version you have does not support your new camera.
          • 2. Re: Help! can't see CR2 thumbnails In Bridge
            jsuttonphotography Level 1
            ok, done, I have installed the latest camera raw plug in 5.4
            and I still cannot see the CR2 thumbnails in Bridge
            my small jpegs are showing just fine.
            please somebody help me solve this
            • 3. Re: Help! can't see CR2 thumbnails In Bridge
              …and did you remember to Purge the Cache for the folder(s) through the Tools menu in Bridge as per the instructions?
              Finally, are you sure you are shooting true raw files and not the sRAW format?  The sRAW format, a proprietary Canon image file format, is not supported as those are not true raw files.  Check yor camera settings.
              • 4. Re: Help! can't see CR2 thumbnails In Bridge
                Also, where exactly have you installed the Camera Raw plug-in?
                Check in the About Plug-in… menu item.   There should be only one instance of ACR there, and it should say ACR 5.4.
                • 5. Re: Help! can't see CR2 thumbnails In Bridge
                  Hi - Joan's husband here (I built the computer hardware for her, but don't
                  really know Photoshop that well). I did a search for "camera raw" files and
                  found a second instance located in the adobe/common files folder (not in
                  program file subfolders as the proper plugin is located per instructions).
                  It was the 5.0 version, and I could not do anything with it, eg delete it as
                  it "was in use by a program", even though I had no prgrams open. I was able
                  to rename it to "old camera raw 5-0", and I copied the new camera raw 5.4
                  version into that folder. I rebooted and now had 3 camera raw plugins
                  appearing in CS4/hlep/about/plugins drop down list.
                  I then went back into the common file folder and was able to delete the old
                  camera raw file. I now have two camera raw files appearing in the
                  help/aboutplugins dropdwon, but they are both the same 5.4 version. Now I am
                  able to see a selection to generate a high quality thumbnail for the cs2
                  files in Bridge when I right-clicked on those, and this generated the
                  thumbnails for all of those file types. All is well now (I hope !!), thanks
                  for your input and advice.
                  I did purge the cache, but that didn't change anything as far as I could
                  tell. Also, the 5.4 update doesn't show the Canon 5D Mark II on the list of
                  updated cameras for this revision, so I don't think it is a necessary update
                  for this specific camera, but probably good to stay current.
                  If this was an "end-run" around a proper fix then I would like to know the
                  proper way to resolve this.
                  Best Regards,
                  Jeff Sutton
                  Joan Sutton Photography
                  6 Longmeadow Lane
                  Medway, MA  02053
                  508-533-1371
                  www.joansutton.com
                  • 6. Re: Help! can't see CR2 thumbnails In Bridge
                    Jeff,
                    You can have only ONE (1) instance of the Camera Raw plug-in installed.  Period.
                    Renaming the Camera Raw plug-in does NOT hide it from Photoshop and Bridge as long as it's remotely anywhere in the Photoshop path.  It MUST be removed.  Renaming it is akin to putting a used tissue in your pocket after blowing your nose instead of discarding it entirely; you'll retain all the germs.
                    Your wife must have set Bridge in Preferences to launch automatically and silently in the background whenever she boots up her machine.  Bring Bridge to the front, then EXIT the Bridge application—and Photoshop too if it's running.  You should be able to remove any plug-in you want now.
                    Your mention of building the computer yourself is the first hint of its being a Windows box.  If it were a Mac, I'd show you screenshots.
                    • 7. Re: Help! can't see CR2 thumbnails In Bridge
                      Incidentally, it's a monumentally bad idea to post all that personal information in public.
                      You're exposed to the spambots and to every nut in the Internet now.
