7 Replies Latest reply on Aug 3, 2009 8:10 PM by fiascoed
    Externally Loaded .SWF Issue
    fiascoed
      I've loaded an external .swf into a movieclip in my parent .swf using the loadMovie(); function. The file loads perfectly and in the right position, however I can no longer access the functions of the external .swf. When I load the file into a level rather than a movieclip, the functions (buttons and timeline) of the external .swf work properly.
      Is there any way to use the functions of the external .swf when I load it into an empty movie clip?
      Thanks in advance
        • 1. Re: Externally Loaded .SWF Issue
          webqaflash Level 3
          loadMovie("load.swf",loader_mc);    //OR  loader_mc.loadMovie("load.swf");
          In the above case load.swf loaded in movieclip loader_mc.
          If there is a function exists in the load.swf you can call as loader_mc.yourfunction();
          • 2. Re: Externally Loaded .SWF Issue
            fiascoed Level 1
            Thanks for the reply
            Unfortunately that's already the code I'm using to load the .swf in -- this file consists of several movie clips with rollover effects. Is that my issue?
            • 3. Re: Externally Loaded .SWF Issue
              webqaflash Level 3
              I think rollover effect is not aproblem.
              First test this calling a function in the loaded swf by  creating two test swfs.
              • 4. Re: Externally Loaded .SWF Issue
                Sreelash Level 1
                Hi, Load swf with the following code:
                var mcl:MovieClipLoader=new MovieClipLoader();
                var lo:Object=new Object();
                lo.onLoadProgress=function(target:MovieClip,bl:Number,bt:Number){
                // create your preloader using bl(= bytes loaded) and bt(=bytes total)
                mcl.addListener(lo);
                mcl.loadClip("001.swf",1);
                Actually the issue may due to the movieclips. Yoe are loading the external swf on a movieclip na? The rollover effect is not working after the swf loaded may due to this. Please reply me.
                Thanks and regards,
                                          Sreelash
                • 5. Re: Externally Loaded .SWF Issue
                  webqaflash Level 3
                  Why don't you use loadMovie
                  var container:MovieClip = this.createEmptyMovieClip("container", getNextHighestDepth());
                  container.loadMovie("load.swf");
                  test_btn.onRelease = function() {
                      container.test();
                  Place a button on parent movie(instantname  test_btn);
                  Write a function test in the load swf
                  • 6. Re: Externally Loaded .SWF Issue
                    Sreelash Level 1
                    Hi friend,
                              swf can load with loadMovie also. In this case, you are loading swf inside a movieclip named container. In this case , when  onRollOver or onPress events are using on the loaded swf, I doubt that whether these events may work or not. have you tested with this. Can you please clarify my doubt. Thats why I used loadClip method. I am not sure whether i am thinking in right way.
                    Thanks and Regards,
                                         Sreelash
                    • 7. Re: Externally Loaded .SWF Issue
                      fiascoed Level 1
                      Thanks for all the help -- turns out I just needed a _lockroot command on my empty movie clip
