5 Replies Latest reply on Aug 3, 2009 3:32 AM by nikos101
    Checkboxes in ADG are acting like radiobuttons only letting me select one checkbox at a time
    nikos101 Level 2
      I have the following AdvancedDataGridColumn
      <mx:AdvancedDataGridColumn width="35" itemEditor="CheckBoxRenderer" itemRenderer="CheckBoxRenderer" showDataTips="true" editable="false">
                                  </mx:AdvancedDataGridColumn>
      However the checkboxes are acting like radiobuttons only letting me select one checkbox at a time. Any ideas how to fix this?
        • 1. Re: Checkboxes in ADG are acting like radiobuttons only letting me select one checkbox at a time
          ShardulSingh Level 3
          Pls use itemRenderer instead of itemEditor it will work perfectly.
          Remove ItemEditor from here.
          with Regards,
          Shardul Singh Bartwal
          • 2. Re: Checkboxes in ADG are acting like radiobuttons only letting me select one checkbox at a time
            nikos101 Level 2
            Thanks, I just tested it and I'm still having the same problem
                <mx:AdvancedDataGridColumn width="35" itemRenderer="CheckBoxRenderer" showDataTips="true" editable="false">
            • 3. Re: Checkboxes in ADG are acting like radiobuttons only letting me select one checkbox at a time
              nikos101 Level 2
              heres the code for the CheckBoxRenderer
              package
              import flash.display.DisplayObject;
              import flash.events.KeyboardEvent;
              import flash.events.MouseEvent;
              import flash.text.TextField;
              import mx.controls.CheckBox;
              import mx.controls.advancedDataGridClasses.AdvancedDataGridListData;
              import mx.controls.listClasses.ListBase;
              *  The Renderer.
              public class CheckBoxRenderer extends CheckBox
                  public function CheckBoxRenderer()
                      focusEnabled = false;
                  override public function set data(value:Object):void
                      super.data = value;
                      if(data != null){
                      super.data.isSelected = false;
                      this.selected = false;
                      invalidateProperties();
                  override protected function commitProperties():void
                      super.commitProperties();
                      if (owner is ListBase)
                          selected = ListBase(owner).isItemSelected(data);
                  /* eat keyboard events, the underlying list will handle them */
                  override protected function keyDownHandler(event:KeyboardEvent):void
                  override protected function keyUpHandler(event:KeyboardEvent):void
                  /* eat mouse events, the underlying list will handle them */
                  override protected function clickHandler(event:MouseEvent):void
                        super.clickHandler(event);
                      if(!data.isSelected){
                          data.isSelected = true;
                      }else{
                  /* center the checkbox if we're in a datagrid */
                  override protected function updateDisplayList(w:Number, h:Number):void
                      super.updateDisplayList(w, h);
                      if (listData is AdvancedDataGridListData)
                          var n:int = numChildren;
                          for (var i:int = 0; i < n; i++)
                              var c:DisplayObject = getChildAt(i);
                              if (!(c is TextField))
                                  c.x = (w - c.width) / 2;
                                  c.y = 0;
              • 4. Re: Checkboxes in ADG are acting like radiobuttons only letting me select one checkbox at a time
                nikos101 Level 2
                This line of code is the prblem
                but I don't know why
                        super.data = value;
                        if(data != null){
                • 5. Re: Checkboxes in ADG are acting like radiobuttons only letting me select one checkbox at a time
                  nikos101 Level 2
                  this code fixed it
                          super.data = value;
                          if(super.data.isSelected == null){
                          data.isSelected = this.selected;
