3 Replies Latest reply on Jul 30, 2008 9:07 PM by SiamJai
    Moving Images
    Lucy7787
      how do I make images to move without that pause between every move??
      I know how to make them move but there's a pause between every move/frame, I would like not to have that pause cause it looks bad, I would like the images and text to flow. So can anyone help me? Thanks!
        • 1. Re: Moving Images
          SiamJai Level 2
          Hi Lucy,
          When you look at the Frames panel (Shift+F2), you'll see a number on the right side of each frame. Double click on that number and change it to something smaller (from 7 to 5, for example). This will decrease the pause between frames. But, as you will notice it, it will also make the animation go a bit faster.
          If you'd like to keep the speed the same, you will have to insert more frames in addition to decreasing the frame delay.
          I hope that helps,
          SiamJai
          http://design.thaiwonders.com - Innovative Fireworks Tutorials
          • 2. Re: Moving Images
            Lucy7787 Level 1
            Thanks a lot SiamJai!!
            It was just what I wanted...
            bye :)
            • 3. Re: Moving Images
              SiamJai Level 2
              You're welcome, Lucy. :-)
