0 Replies Latest reply on Aug 3, 2009 4:04 AM by J van E
    Could anyone help me to get this script working?
    J van E Level 1
      I've got this CS2 script that worked in CS3 after putting in the Version 4.0 Scripts folder (never mind the Dutch dialog). But this trick doesn't do it in CS4. I wonder if anyone could rewrite it for CS4...? I know absolutely nothing about scripts, so er... I don't need directions on how to solve this problem: I just need a working script. Thanks in advance!
      tell application "Adobe InDesign CS3"
      set «class pFnd» to nothing
      set «class pChg» to nothing
      set mySel to selection
      if (length of mySel) = 0 then
      display dialog "Fout! Selecteer één (of meerdere) tekstkader(s)" & return & ¬
      "met één van de twee pijltjes!"
      else if class of item 1 of mySel is not text frame then
      else
      try
      if class of item 1 of mySel is text then
      set mySearch to «class pTxF» of selection
      else if class of item 1 of mySel is text frame then
      set mySearch to mySel
      end if
      «event K2  Find» mySearch given «class for »:",,", «class FRpT»:"<0022>"
      «event K2  Find» mySearch given «class for »:"‘‘", «class FRpT»:"<0022>"
      «event K2  Find» mySearch given «class for »:"’’", «class FRpT»:"<0022>"
      «event K2  Find» mySearch given «class for »:"“", «class FRpT»:"<0022>"
      «event K2  Find» mySearch given «class for »:"”", «class FRpT»:"<0022>"
      «event K2  Find» mySearch given «class for »:"„", «class FRpT»:"<0022>"
      «event K2  Find» mySearch given «class for »:"‘", «class FRpT»:"<0027>"
      «event K2  Find» mySearch given «class for »:"’", «class FRpT»:"<0027>"
      «event K2  Find» mySearch given «class for »:"´", «class FRpT»:"<0027>"
      «event K2  Find» mySearch given «class for »:"<0020><0020>", «class FRpT»:"<0020>"
      «event K2  Find» mySearch given «class for »:"^t^t", «class FRpT»:"^t"
      «event K2  Find» mySearch given «class for »:"^p^p^p", «class FRpT»:"^p^p"
      «event K2  Find» mySearch given «class for »:"^p<0020>", «class FRpT»:"^p"
      on error
      end try
      end if
      end tell
