4 Replies Latest reply on Aug 15, 2009 4:18 AM by Chunick
    How to turn off 'Trim White Space' with Lingo?
    tem009
      I have a bitmap member on the stage, and when stage is loading some image must be loaded to that bitmap member (and resized and positioned). Currently I have a code which works, but it trims the white space from the image and even if I import the first image and take off "Trim White Space" option, the option is turned back on when some other image is loaded to the member.
      The code I'm currently using is:
          member("pic").filename = the pathname & "pics/" & picture_1
          member("pic").picture = member("pic").picture
          sprite("pic_sprite").width = "200"
          sprite("pic_sprite").height = "100"
          sprite("pic_sprite").locH = 192
          sprite("pic_sprite").locV = 294
      Is there a way to turn off that white space trim or is there a better way to load a image to the stage?
        • 1. Re: How to turn off 'Trim White Space' with Lingo?
          Chunick Level 3
          ImportFileInto - undocumented parameters: http://collab.directorforum.com/Undocumented_Lingo#importFileInto_with_castLib_files
          Stretch property of sprites: http://collab.directorforum.com/Undocumented_Lingo#stretch_property_of_sprites
          Here's the code I would use:
          -- create a new image member
          mem = new(#bitmap)
          -- import your external image to the new image member
          mem.importFileInto( the pathname & "pics/" & picture_1, [#trimWhiteSpace: false])
          -- make sure the stretch property is set to true on the sprite
          -- so that the dimensions are maintained... this is based off what I see in your code
          sprite("pic_sprite").stretch = true
          -- set the new member to the sprite
          sprite("pic_sprite").member = mem
          as well, in authoring, when you create a member it stays, so I would also put code like this somewhere to clean up the member:
          mem.erase()
          usually, you put it in a on endSprite handler or on stopMovie handler but because you do not show where your code is, I can only make assumptions. Also remember about variable scope, depending on how you've structured your code, you might need to make it a global or property variable. Finally, use "Save and Compact" as that will clean up the garbage that gets saved into the .dir... especially make sure to do "Save and Compact" just before publishing.
          btw, using the .picture property of a member is depricated in favor of the .image in newer versions of Director.
          is now,
          member("pic").image
          • 2. Re: How to turn off 'Trim White Space' with Lingo?
            fazstp Level 2
            You can set the trimWhiteSpace flag but I know in MX2004 it wouldn't work until it was relinked.
            member( "pic" ).fileName = the pathname & "pics/" & picture_1
            member( "pic" ).trimWhiteSpace = FALSE
            • 3. Re: How to turn off 'Trim White Space' with Lingo?
              miche_r Level 1
              So even though the created member stays when I'm in authoring mode, it doesn't stay in projector mode, right? Director help says that using erase method in projector may cause memory problems. Is that true?
              About that erase method: I have four different pictures on different pages, and sometimes all pictures aren't necessarily loaded. How I could check if the member is created before erasing it, because sometimes I get an error when I try to erase mem4, but that member hasn't been created (I have put the erase method on exit button).
              • 4. Re: How to turn off 'Trim White Space' with Lingo?
                Chunick Level 3
                your code sounds a bit messy, but here's something that you might be able to run with:
                if the runMode = "Author" then
                  -- run through all your possible members and see if they exist
                  -- which is where I'm guessing how you've set things up
                  repeat with j = 10 to 20
                    if member(j).type <> #empty then
                      member(j).erase()
                    end if
                  end repeat
                end if
                And to answer your question; Erasing members is quite safe. I wouldn't worry about erasing members during runtime if you're creating a fairly limited number of them.
