2 Replies Latest reply on Aug 6, 2009 12:06 AM by dalcde
    Need help with Random Blur
    onisamagolf
      I'm using a custom BlurTween class, but that isn't the problem.  I've got the following AS targeting a clip with the insstance name of photo:
      // All time in milliseconds. (1000 = 1 second)
      import com.rubenbristian.tween.BlurTween;;
      maxTB = 5000; // Maximum time between blur
      minTB = 2000; // Minimum time between blur
      maxBD = 5000; // Maximum blur duration
      minBD = 2000;  // Minimum blur duration
      // Get a random start time.
      blurTime = getNewTime();
      blurDuration = getNewDuration();
      // Every frame execute the following code.
      this.onEnterFrame = function(){
           // Get current time in milliseconds.
           curTime = getTimer();
           // Check if current time is past the time to blur.
           if(curTime >= blurTime){
                // blurring already.
                // Check if blur has lasted the duration specified.
                   if(curTime <= blurTime + blurDuration){
                     // Create the blur.
                     var blur_amt_x = 20;
                     var blur_amt_y = 5;
                     new BlurTween(photo, "out", blur_amt_x, blur_amt_y, 1, .7, "Strong", "out");
                } else {
                     // Clear blur filter
                     var blur_amt_y = 5;
                     new BlurTween(photo, "in", blur_amt_x, blur_amt_y, 1, .7, "Strong", "out");
      // Create a random time between maxTB and minTB specified.
      function getNewTime(){
           return getTimer() + (Math.random() * (maxTB-minTB))+minTB;
      // Create a random duration between maxBD and minBD
      function getNewDuration () {
           return (Math.random() * (maxBD-minBD)) + minBD;
      Everything is working OK, except the duration of the blur doesn't seem to be working.  The clip blurs and then is "immediately" sharp agian.  I want the clip to stay blurred for a random duration which I'm setting with the variable blurDuration.  I just can't figure out why it isn't staying blurred.  I modified the AS from a random flicker tutorial I found.
      Shannon
        • 1. Re: Need help with Random Blur
          onisamagolf Level 1
          I had a combination of things going wrong, here is what I ended up doing:
          minTB = 100; // Minimum time between blur
          maxBD = 1000; // Maximum blur duration
          minBD = 50;  // Minimum blur duration
          blurCount = 0;
          trace(blurCount + "a");
               trace(blurCount + "b");
               trace(curTime);
               trace(blurTime);
               trace(blurTime + blurDuration);
               if((curTime >= blurTime) && (blurCount == 0)){
                    // Create the blur.
                    var blur_amt_y = 5;
                    new BlurTween(photo, "out", blur_amt_x, blur_amt_y, 1, 1, "Strong", "out");
                    ++blurCount;
                    trace(blurCount + "c");
               else if (curTime >= blurTime + blurDuration) {
                    var blur_amt_y = 5;
                    new BlurTween(photo, "in", blur_amt_x, blur_amt_y, 1, 1, "Strong", "in");
                    trace(blurCount + "d");
                    blurCount = 0;
                    trace(blurCount + "e");
               return getTimer() + (Math.random() * (maxTB-minTB))+ minTB;
          • 2. Re: Need help with Random Blur
            dalcde Level 1
            I don't really understand much of your code, but the minimum blur duration: 0.05 seconds, and maximum blur duration: 1 second. So I don't expect it to last long. Try multiplying it by 100.
