3 Replies Latest reply on Aug 4, 2009 8:46 AM by cynthia_delaria
    Issue in IE - SWF delivered over SSL loads, but HTTPService result is never fired
    cynthia_delaria
      Hey all!
      I am having an issue and haven't found anything that will fix it... So I'm hoping that someone here will see this and know of a solution.
      I am running on a dev environment, over ssl, and my flex app loads beautifully in firefox... If I switch to non-ssl (http) then IE works great too... However over ssl (https) the movie loads but the HTTPService requests never load their data. Using Fiddler, I can see that there is in fact a response body in there with my expected XML, however for some reason the result never gets acknowledged by the app in IE.
      Any ideas? I'm using relative paths on all of my HTTPService urls, so that doesn't seem to be the problem, and I have made the appropriate changes so that there is no more mixed security error. Also, everything is running on the same domain, so there is no crossdomain xml file, and shouldn't need to be one since everything runs on the same box/url. We do have self-signed certs, but I've found enough posts here that say that shouldn't be the problem to have ruled that out.
      I found a couple of posts that talked about changing some of the headers in the response, specifically Pragma: no-cache, and Cache-Control: no-cache... I do see these headers, but I can't for the life of me figure out where they are coming from in my middleware... Is this really the thing that will fix this for me, or is there something else I'm missing?
      Thanks!
