0 Replies Latest reply on Aug 3, 2009 11:58 AM by Brent Lamborn
    RepeatedBackground w/ Scaling
    Brent Lamborn
      I'm running into a bit of an issue trying to repeat a background across the entire visible area of a Flex app in the browser. First I am using Alex's method of enabling scaling in a Flex app which he outlines here:
      http://blogs.adobe.com/aharui/2008/01/flex_and_scalemodes.html
      It works perfectly to scale our app. Then to do the repeated background, I use Degrafa like Doug McCune's example here:
      http://dougmccune.com/360Flex_ATL/WindowShadeDegrafa/
      I have my application width and height set to 1024 x 768 respectively. What happens then, is that the background is repeated only over the 1024  x 768 area of the app, not the actual full visible are of the application which amounts to a lot of area on my 1680 x 1050 resolution monitor.
      I should also note that I cannot use wmode="transparent" in the HTML wrapper, since it causes scrolling issue in parts of our application.
      Anyone have ideas on how to repeat a background across an entire Flex app, that has scaling enabled without using wmode="transparent"?
      -Brent
