0 Replies Latest reply on Aug 3, 2009 11:58 AM by polmbo
    Customization Wizard
    polmbo
      I tried using the Customization wizard without luck but I did find the Registry edits in the Help. I need to be able to disable the two buttons that allow access to outside websites.
      - Share documents and collaborate live within PDF files
      - Create Adobe PDF Using Acrobate.com
      If I use [HKEY_CURRENT_USER\Software\Adobe\Acrobat  Reader\9.0\Workflows] "bEnableAcrobatHS"=dword:00000000 I can get both of these buttons to go away for the current USER. The problem is I need it to disappear for every user that logs onto the server.
      If I use [HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Adobe\Acrobat  Reader\9.0\FeatureLockdown] "bCreatePDFOnline"=dword:00000000 it will only remove - Create Adobe PDF Using Acrobate.com button for everyone logging in. Anyone know of a command that will also get rid of - Share documents and collaborate live within PDF files in the Local_Machine
      Should I maybe look at running a script that would set the registry for everyone that logs on?
