2 Replies Latest reply on Aug 3, 2009 3:24 PM by prisma7-IALD6z
    Action Sequences
    prisma7-IALD6z
      On the time line, there's an option for Action Sequences.
      What is that?
      How does it work?
      Thank you for your help.
        • 1. Re: Action Sequences
          Matt Cannizzaro
          When you create states, the timelines panel will automatically create timelines that are transitions between your states. These timelines will play whenever your application or component moves between states.
          An action sequence is just a timeline that is not tied to a state transition. To create an action sequence, use the interactions HUD. Look for the "Play Action Sequence" option. Once you've chosen this, an action sequence will be created in the timelines panel for you. You can use any of the effects that you would use in a state transition in an action sequence as well.
          • 2. Re: Action Sequences
            prisma7-IALD6z Level 1
            Thank you very much.
            I'll give it a try.
