0 Replies Latest reply on Aug 3, 2009 4:16 PM by Jason Szeto
    [svn:fx-3.x] 9030: Adding support for multiple error messages in UIComponent
    Jason Szeto Level 3
      Revision: 9030
      Author:   jszeto@adobe.com
      Date:     2009-08-03 16:15:54 -0700 (Mon, 03 Aug 2009)
      Log Message:
      http://bugs.adobe.com/jira/browse/SDK-11973 - Multiple validators on one UI element should not clobber each other
      UIComponent receives multiple event notifications that an attached validator has succeeded or failed. However, it was not handling multiple errors or combinations of errors and successes in the correct manner.
      Thanks to Aaron Boushley for submitting this patch. His patch stores the error messages and validators in an error state into a couple of arrays. When a validation result event is received, we either add or remove items to these arrays.
      I updated some variable names to match the correct Flex coding style and delayed the creation of the error arrays until the first validation result event is received.
      QE notes: Add tests for this use case
      Doc notes: Add documentation for this use case
      Bugs: SDK-11973
      Reviewer: Jason
      Tests run: Validators
      Is noteworthy for integration: No
      Ticket Links:
      Modified Paths:
          flex/sdk/branches/3.x/frameworks/projects/framework/src/mx/core/UIComponent.as
