15 Replies Latest reply on Sep 17, 2009 4:40 AM by flexprad09
    Maps in Flex Please Help
    sri harsha namala Level 2
      Hi all,
                I Strucked up with Maps in Flex , In my Project i have to display  county Map with  Mapping for all States.
                How to achive this?Please Help me.
                Here is the link  For Similar type of  Map which i have  to achive?
                http://www.ndtv.com/elections/maps.php
                Any Samples on this Type of Applications or Please give me some Ideas how to do?
        • 1. Re: Maps in Flex Please Help
          flexprad09 Level 2
          You can use ILOg elixir which goes well with flex.
          they have some built in maps or you can make your custom ones.
          this link shows some info.
          http://jviews.com/products/ilogelixir/features/maps/
          Regards,
          Prad.
          If this post answers your question or helps, please mark it as such.
          • 2. Re: Maps in Flex Please Help
            Gregory Lafrance Level 6
            These resources should answer your question (involves Yahoo maps and Google maps):
            http://www.flexpasta.com/index.php/2008/04/09/getting-started-with-maps-in-flex-3/
            http://developer.yahoo.com/flash/maps/
            http://mprami.wordpress.com/2008/05/15/google-maps-api-for-actionscript-3-flex-and-flash/
            • 3. Re: Maps in Flex Please Help
              Can i achieve this without using yahooaps or google maps my data is static and will not be changed dynamically.
              • 4. Re: Maps in Flex Please Help
                Anthony T DeBonis Level 1
                We have used Flash based maps like these: http://www.flashimap.com/show.php?code=UNITED_STATES
                When we dont need a full GIS system just shapes.
                We had to do it for all the countied in NYS and it worked well as a Flash based component inside Flex.
                • 5. Re: Maps in Flex Please Help
                  FangAvtar
                  Did you have any .fla file same as the link that you provided?
                  • 6. Re: Maps in Flex Please Help
                    For what you are trying to do, these links may be good:
                    http://dougmccune.com/blog/2007/03/13/imagemap-component-added-to-flexlib/
                    http://code.google.com/p/flexlib/wiki/ComponentList
                    • 7. Re: Maps in Flex Please Help
                      FangAvtar Level 1
                      As per the provided link i have implement the mxml file.But got a error."Could not resolve <ImageMap> to a component implementation".I have put the usa.jpg file on src filder where the maml is present.
                      Actually I want http://www.usflashmap.com/products/real_estate_maps/us_flash_map.htm goto view example option.
                      Thanks in advance
                      • 8. Re: Maps in Flex Please Help
                        flexprad09 Level 2
                        HEyy Namala,
                        I have exactly similar requirements like you.
                        Were you able to achieve that ndtv type map.
                        If yes please let me know how to do it.
                        Any links or pointers are also highly appreciated.
                        I only want shapes and click events no GIS or extended functionality.
                        thanks ,
                        PRad.
                        • 9. Re: Maps in Flex Please Help
                          flexprad09 Level 2
                          Greg ,
                          I was not able to implement Imagemap given in links you mentioned.
                          coz i was not able to resolve area component used.  it was neither found in mx nor in flexlibs.
                          does it come from flash.
                          Please help.
                          Regards,
                          Prad.
                          • 10. Re: Maps in Flex Please Help
                            I got this to work.
                            - Download the zip from here:    http://code.google.com/p/flexlib/downloads/list
                            - Unzip the file and put the SWC file in the same file as the project mxml file.
                            - In Flex Builder, Project - Properties - Flex Build Path - Library Path tab - Add SWC... then navigate to the SWC
                            - Get the image from here:      http://hotpads.com/    (right-click, save image as, then rename as usa.jpg)
                            - Replace your mxml file with this code:
                            <?xml version="1.0" encoding="utf-8" ?>
                            Copyright (c) 2007 FlexLib Contributors.  See:
                                http://code.google.com/p/flexlib/wiki/ProjectContributors is hereby granted, free of charge, to any person obtaining a copy of
                            this software and associated documentation files (the "Software"), to deal in
                            the Software without restriction, including without limitation the rights to
                            use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies
                            of the Software, and to permit persons to whom the Software is furnished to do
                            so, subject to the following conditions:
                            Permission
                            The above copyright notice and this permission notice shall be included in all
                            copies or substantial portions of the Software.
                            THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
                            IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
                            FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
                            AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
                            LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
                            OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
                            SOFTWARE.
                            <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical" backgroundGradientColors="[#FFFFFF, #FFFFFF]" horizontalAlign="center" verticalAlign="middle" verticalScrollPolicy="off" horizontalScrollPolicy="off">
                              <mx:CheckBox id="chk" label="Show outlines" />
                            <ImageMap xmlns="http://code.google.com/p/flexlib/" scaleContent="true" source="usa.jpg" outlineAlpha="{chk.selected ? 1 : 0}" outlineColor="0x00ff00" fillAlpha="{chk.selected ? .5 : 0}" fillColor="0xff0000" showToolTips="true" width="100%" maxWidth="554" shapeClick="navigateToURL(new URLRequest(event.href), event.linkTarget)">
                            <map>
                              <area alt="WA" shape="POLY" coords="85,11,133,11,134,42,114,42,100,47,96,45,91,48,83,40,76,40,75,29,70,23,71,18,82,20,87,18" href="http://en.wikipedia.org/wiki/Washington" target="_blank" />
                              <area alt="OR" shape="POLY" coords="76,40,83,40,90,48,96,45,101,47,115,43,134,43,138,46,133,57,134,84,72,84,71,71,76,56" href="http://en.wikipedia.org/wiki/Oregon" target="_blank" />
                              <area alt="CA" shape="POLY" coords="73,84,108,84,109,116,158,161,153,172,153,179,133,182,126,169,105,161,91,139,81,120,73,100" href="http://en.wikipedia.org/wiki/California" target="_blank" />
                              <area alt="HI" shape="POLY" coords="5,117,12,118,44,129,54,137,69,151,56,162,50,140,27,130,3,122" href="http://en.wikipedia.org/wiki/Hawaii" target="_blank" />
                              <area alt="AK" shape="POLY" coords="165,202,165,251,176,255,183,254,197,274,194,279,173,256,143,245,140,252,132,253,130,267,89,281,113,257,100,256,87,242,103,230,84,227,87,217,100,220,89,206,115,192" href="http://en.wikipedia.org/wiki/Alaska" target="_blank" />
                              <area alt="ID" shape="POLY" coords="134,11,142,11,142,24,156,36,154,47,159,47,166,57,183,56,183,83,135,83,133,56,138,46,134,41" href="http://en.wikipedia.org/wiki/Idaho" target="_blank" />
                              <area alt="NV" shape="POLY" coords="109,84,158,84,158,142,153,145,152,156,109,116" href="http://en.wikipedia.org/wiki/Nevada" target="_blank" />
                              <area alt="AZ" shape="POLY" coords="159,136,199,136,199,194,181,194,151,182,154,179,154,170,158,161,152,155,153,145,159,144" href="http://en.wikipedia.org/wiki/Arizona" target="_blank" />
                              <area alt="UT" shape="POLY" coords="199,135,158,135,159,84,183,84,183,94,199,94" href="http://en.wikipedia.org/wiki/Utah" target="_blank" />
                              <area alt="MT" shape="POLY" coords="142,11,241,11,241,52,182,52,182,55,166,57,159,46,154,47,156,35,142,23" href="http://en.wikipedia.org/wiki/Montana" target="_blank" />
                              <area alt="WY" shape="POLY" coords="182,52,241,52,241,95,183,94" href="http://en.wikipedia.org/wiki/Wyoming" target="_blank" />
                              <area alt="CO" shape="POLY" coords="200,95,257,95,257,136,200,136" href="http://en.wikipedia.org/wiki/Colorado" target="_blank" />
                              <area alt="NM" shape="POLY" coords="200,136,249,136,249,186,219,187,207,189,207,194,200,194" href="http://en.wikipedia.org/wiki/New Mexico" target="_blank" />
                              <area alt="ND" shape="POLY" coords="241,11,297,11,298,19,302,43,242,43" href="http://en.wikipedia.org/wiki/North Dakota" target="_blank" />
                              <area alt="SD" shape="POLY" coords="242,43,302,43,300,47,304,50,304,68,302,77,295,75,290,75,286,73,242,73" href="http://en.wikipedia.org/wiki/South Dakota" target="_blank" />
                              <area alt="NE" shape="POLY" coords="242,73,286,73,290,76,302,77,314,104,258,104,258,94,242,94" href="http://en.wikipedia.org/wiki/Nebraska" target="_blank" />
                              <area alt="KS" shape="POLY" coords="257,104,315,104,319,114,318,136,257,135" href="http://en.wikipedia.org/wiki/Kansas" target="_blank" />
                              <area alt="OK" shape="POLY" coords="249,136,319,136,320,169,314,166,300,169,295,166,286,166,275,160,274,141,249,141" href="http://en.wikipedia.org/wiki/Oklahoma" target="_blank" />
                              <area alt="TX" shape="POLY" coords="249,141,273,141,274,160,288,167,296,167,300,169,312,167,323,171,323,188,328,197,326,210,310,219,296,235,297,248,283,245,270,220,259,209,249,212,248,219,234,211,230,196,220,187,249,187" href="http://en.wikipedia.org/wiki/Texas" target="_blank" />
                              <area alt="MN" shape="POLY" coords="297,11,313,11,315,8,321,14,333,15,345,21,360,21,338,36,337,41,333,44,335,56,347,65,346,68,304,68,304,49,300,47,302,43,300,24" href="http://en.wikipedia.org/wiki/Minnesota" target="_blank" />
                              <area alt="IA" shape="POLY" coords="304,68,345,68,355,82,352,89,348,90,345,99,311,99,307,88,303,77" href="http://en.wikipedia.org/wiki/Iowa" target="_blank" />
                              <area alt="MI" shape="POLY" coords="311,98,344,98,346,107,352,116,356,117,354,124,361,128,364,140,359,146,355,146,355,140,319,140,318,113,315,110,315,105" href="http://en.wikipedia.org/wiki/MIssouri" target="_blank" />
                              <area alt="AR" shape="POLY" coords="318,140,355,140,355,145,360,145,355,156,352,158,351,162,348,165,347,177,323,177,323,172,320,169,320,150" href="http://en.wikipedia.org/wiki/Arkansas" target="_blank" />
                              <area alt="LA" shape="POLY" coords="323,176,346,177,349,182,344,197,358,197,360,202,360,210,364,216,353,217,339,212,326,209,328,194,323,187" href="http://en.wikipedia.org/wiki/Loisiana" target="_blank" />
                              <area alt="WI" shape="POLY" coords="342,34,349,32,357,37,372,42,377,49,374,56,381,53,375,78,352,78,347,68,348,64,335,55,333,44,338,40,339,35" href="http://en.wikipedia.org/wiki/Wisconsin" target="_blank" />
                              <area alt="MI" shape="POLY" coords="357,35,373,28,378,37,399,34,412,41,403,46,412,53,406,67,416,62,421,74,412,86,383,86,389,77,388,54,395,53,399,44,393,43,378,48,370,41,356,37" href="http://en.wikipedia.org/wiki/Michigan" target="_blank" />
                              <area alt="IL" shape="POLY" coords="353,78,375,78,377,88,377,112,374,124,374,131,368,134,366,133,362,135,361,127,354,123,357,116,347,109,345,99,349,90,354,86,355,81" href="http://en.wikipedia.org/wiki/Illinois" target="_blank" />
                              <area alt="IN" shape="POLY" coords="379,88,384,86,401,87,401,114,393,119,392,123,385,124,381,126,375,126,375,121,378,109" href="http://en.wikipedia.org/wiki/Indiana" target="_blank" />
                              <area alt="KY" shape="POLY" coords="364,140,365,133,372,132,378,126,392,124,395,118,403,114,410,118,417,118,423,131,412,139" href="http://en.wikipedia.org/wiki/Kentucky" target="_blank" />
                              <area alt="TN" shape="POLY" coords="364,140,425,139,424,143,417,146,409,151,403,156,355,156" href="http://en.wikipedia.org/wiki/Tennessee" target="_blank" />
                              <area alt="MS" shape="POLY" coords="355,156,371,156,370,201,359,202,345,196,349,164" href="http://en.wikipedia.org/wiki/Mississippi" target="_blank" />
                              <area alt="AL" shape="POLY" coords="372,156,393,156,399,187,398,198,377,198,379,204,376,206,370,201" href="http://en.wikipedia.org/wiki/Alabama" target="_blank" />
                              <area alt="OH" shape="POLY" coords="401,86,414,87,419,90,435,84,436,100,433,101,432,108,419,120,401,113" href="http://en.wikipedia.org/wiki/Ohio" target="_blank" />
                              <area alt="FL" shape="POLY" coords="380,203,378,198,399,198,400,200,416,201,422,204,428,199,430,215,438,238,439,254,433,257,416,231,417,218,405,207,395,211,388,203" href="http://en.wikipedia.org/wiki/Florida" target="_blank" />
                              <area alt="GA" shape="POLY" coords="394,156,412,156,413,160,418,164,419,167,425,173,432,186,427,199,422,203,400,200,399,184" href="http://en.wikipedia.org/wiki/Georgia" target="_blank" />
                              <area alt="SC" shape="POLY" coords="413,156,426,154,442,158,451,168,433,186,424,171,418,164,412,159" href="http://en.wikipedia.org/wiki/South Carolina" target="_blank" />
                              <area alt="NC" shape="POLY" coords="404,155,413,155,422,153,442,158,452,169,477,149,474,139,426,139,424,142" href="http://en.wikipedia.org/wiki/North Carolina" target="_blank" />
                              <area alt="WV" shape="POLY" coords="436,101,436,107,444,107,445,111,451,109,452,112,447,119,441,120,439,127,426,133,423,130,418,121,432,108,433,102" href="http://en.wikipedia.org/wiki/West Virginia" target="_blank" />
                              <area alt="DC" shape="POLY" coords="462,114,471,120,469,128,459,125" href="http://en.wikipedia.org/wiki/Washington DC" target="_blank" />
                              <area alt="VA" shape="POLY" coords="414,139,473,139,469,128,459,125,462,114,453,111,448,119,442,120,439,128,426,133,419,131" href="http://en.wikipedia.org/wiki/Virginia" target="_blank" />
                              <area alt="MD" shape="POLY" coords="444,107,444,111,451,109,464,115,471,120,471,111,475,112,477,120,482,120,476,107" href="http://en.wikipedia.org/wiki/Maryland" target="_blank" />
                              <area alt="DE" shape="POLY" coords="471,119,471,112,475,113,477,121,483,122,474,134" href="http://en.wikipedia.org/wiki/Delaware" target="_blank" />
                              <area alt="NJ" shape="POLY" coords="476,107,481,113,489,105,489,98,490,93,483,90,479,96,482,102" href="http://en.wikipedia.org/wiki/New Jersey" target="_blank" />
                              <area alt="PA" shape="POLY" coords="436,106,475,106,482,102,478,95,483,90,479,83,436,83" href="http://en.wikipedia.org/wiki/Pennsylvania" target="_blank" />
                              <area alt="NY" shape="POLY" coords="440,82,479,82,484,90,490,94,490,98,504,96,493,93,496,75,494,63,496,52,474,56,470,69,457,70,451,67" href="http://en.wikipedia.org/wiki/New York" target="_blank" />
                              <area alt="CT" shape="POLY" coords="494,92,507,90,506,84,494,84" href="http://en.wikipedia.org/wiki/Connecticut" target="_blank" />
                              <area alt="RI" shape="POLY" coords="507,90,506,83,513,83,513,89" href="http://en.wikipedia.org/wiki/Rhode Island" target="_blank" />
                              <area alt="MA" shape="POLY" coords="513,89,519,87,515,73,511,76,496,76,495,83,513,83" href="http://en.wikipedia.org/wiki/Massachusetts" target="_blank" />
                              <area alt="VT" shape="POLY" coords="496,75,502,75,504,64,508,58,508,53,496,53,494,64" href="http://en.wikipedia.org/wiki/Vermont" target="_blank" />
                              <area alt="NH" shape="POLY" coords="502,75,512,75,516,71,514,67,513,50,509,54,508,58,503,67" href="http://en.wikipedia.org/wiki/New Hampshire" target="_blank" />
                              <area alt="ME" shape="POLY" coords="516,70,531,59,535,59,547,54,546,50,541,44,540,33,536,29,529,27,521,39,519,45,513,50" href="http://en.wikipedia.org/wiki/Maine" target="_blank" />
                              </map>
                              </ImageMap>
                              </mx:Application>
                            • 11. Re: Maps in Flex Please Help
                              flexprad09 Level 2
                              Okk thanks Greg .
                              Its working.
                              But i still wonder as to whose properties are "area" and "map" ......  is this html .
                              thnkx,
                              Prad
                              • 12. Re: Maps in Flex Please Help
                                Hi FlexPrad,
                                                            I have not yet implemented But this links will surely help us, The Sample Program which these Links provide is working Fine,
                                                            Me sure that we can also Achieve ,If u got any thing just reply to me.
                                • 13. Re: Maps in Flex Please Help
                                  FangAvatar
                                  Greg I have built map in this way.And working fine.But I am not able built shapeOver function.I want on mouseover the state color will change.Please help me.
                                  Thanks in advance.
                                  • 14. Re: Maps in Flex Please Help
                                          Did u get the ShapeOver if u got Please Let me Know
                                    • 15. Re: Maps in Flex Please Help
                                      flexprad09 Level 2
                                      Heyy Namala, FangAvtar
                                      I have implemented it using ILOG Elixir. Thought i  found it very hard to find california state .shp file.
                                      But then it was easy.
                                      It creates two .as files for that .shp file using Custom Map converter of Elixir.
                                      One of which contains coordinates of counties. So we can do Mouse over for counties.
                                      Only concern is if you r allowed to use third party.
                                      for code visit :  http://prady1920.wordpress.com/2009/08/24/custom-interactive-map-in-flex/
                                      Cheers,
                                      Prad.
