1 Reply Latest reply on Aug 4, 2009 5:34 AM by sstanleyau
    CS, CS2 & CS3 place problem
    Mr Bounce Level 1
      I was just wondering if someone could help me with the following problem:
      All l'm doing is placing a text file into a text frame - sounds easy - test code below:
      set boxContent to "HDPropane:textfile.txt"
      tell application "Adobe InDesign CS2"
          activate
          set MyDocument to active document
          try
              set myframe to (text frame 1 of MyDocument whose label is "testbox")
              «event K2  plac» (boxContent) with «class rtfo» without «class imot» given «class insh»:myframe
          on error emg
              display dialog emg
          end try
      end tell
      This works OK and will overwrite the contents each time... the problem is when you link the text frame to another text frame.... it still works fine if you run the script without having any contents in your text frames but as soon as you have some contents you get an error 'import failed'  I get the same problem in CS, CS2 & CS3
      I've even tried after the 'set myframe' adding set myframe contents to "" - adding this line was a little hit and miss  sometimes it worked sometimes l got the same import failed message.
      Regards, Gary.
