0 Replies Latest reply on Aug 4, 2009 9:07 AM by EvolvedDSM
    Handling ResultEvent for data service methods?
    EvolvedDSM Level 2
      I have a dataservice (ds) that makes use of createItem(obj) and deleteItem(obj).  When I call either of these methods, I want to be able to determine which method is being called and then take an action depending on which was performed..
      Here's what I'd like to do...
      ds.addEventListener(ResultEvent.RESULT, dsHandler);
      private function dsHandler(event:ResultEvent):void{
      if(<the ds created an object>){
      ...do this....
      } else if(<the ds deleted the object>){
      ...do something else...
      So how can I write this to do as I described above?  I've read a little bit about using tokens, but I'm not sure if this is the direction I need to be going towards.
      I saw an example of
      private var token:AsyncToken;
      token = ds.createItem(obj);
      token.kind = "create";
      ds.createItem(obj);
      and then...
      if(event.token.kind == "create"){
      ...do this....
      } else if(event.token.kind == "delete"){
      This kinda worked for me, except I kept getting an error that said "Item with id 'CEAD6420-6E28-B2B3-10C9-E62770B9BD13' already exists.  Error on destination 'ds' "  Without this code, I get no error.  The weird thing is that it still creates the item even if it reports the error.  So why is this happening?
      Any help is appreciated.  thanks!
