1 Reply Latest reply on Aug 4, 2009 1:01 PM by ilssac
    Passing XML data  to  variable
    hevi98
      I am currently working on a project which requires XML data.  I would like  to retrieve the dynamic data from sql server using logged in user parameters (depending on the user logged in, the data would differ).  I was able to create a query from either ColdFusion or SQL server internally which resembles the data structure required for the chart, but I cannot figure how to attach the result string from the query to the chart.
      Here is my query:
      <cfquery name="rsXML" datasource="MyDataBase">
      SELECT tag, Parent, [pie!1!slice],[slice!2!title],[slice!2!pull_out],[slice!2!!id]
      FROM dbo.tblIssuesDataForXML
      WHERE CompanyID = var1 and DivisionID = var2
      FOR XML EXPLICIT
      </cfquery>
      This returns the following result:
      <pie><slice title="Group1" pull_out="false">5</slice><slice title="Group2" pull_out="false">19</slice><slice title="Group3" pull_out="false">3</slice><slice title="Group4" pull_out="true">93</slice></pie>
      on a table as follows:
      RecordXML_F52E2B61-18A1-11D1-B105-00805F49916B
      1<pie><slice title="Group1" pull_out="false">5</slice><slice title="Group2" pull_out="false">19</slice><slice title="Group3" pull_out="false">3</slice><slice title="Group4" pull_out="true">93</slice></pie>
      From this point I am not sure how to attach the information correctly to the chart.  I need to pass the XML data as follows:
      so.addVariable("chart_data", encodeURIComponent("<<< YOUR CF GENERATED XML GOES HERE >>>"));
      With numerous attempts I have not been succesful and as you can see I am rather inexperienced in this.  I have received a message saying:
           Complex cannot be converted into simple variable
      I would appreciate any help or insight given here.
      I am currently using ColdFusion 8, Dreamweaver CS3 and SQL Server 2008.
        • 1. Re: Passing XML data  to  variable
          ilssac Level 5
          What is the name of this variable?
          What is the line of code the generated this error?
          Properly combine the variable with the function call and all should be good.
