1. Re: Transcribing only works for short clips?
_durin_ Aug 5, 2009 2:09 PM (in response to bspence11)Did you save the file again after performing the transcription? I don't believe it will automatically be saved with the file after the transcription process is complete. There's no time limitation, although with very large files (upwards of 4 gigabytes) the addition of metadata may force the filesize too large and that might prevent it. This doesn't sound like the problem you're seeing, so I would suspect it just wasn't saved. The 8-hour meeting, I might suggest breaking into smaller pieces anyways, because you are very likely to run into the file size ceiling if/when the file is conformed.
As for the accuracy improving, at this time the dictionary files are static and do not implement any learning behavior. Obviously, the higher quality audio source, the more likely you are to get more accurate transcriptions, but in general, this tool should be used more as a guide and less as an accurate transcript of the audio.
