0 Replies Latest reply on Aug 4, 2009 1:12 PM by Jason Szeto
    [svn:fx-trunk] 9072: http://bugs.adobe.com/jira/browse/SDK-22453 - [ Gumbo_priority] there is no updateComplete event after a fxg component moves
    Jason Szeto Level 3
      Revision: 9072
      Author:   jszeto@adobe.com
      Date:     2009-08-04 13:12:13 -0700 (Tue, 04 Aug 2009)
      Log Message:
      http://bugs.adobe.com/jira/browse/SDK-22453 - there is no updateComplete event after a fxg component moves
      SpriteVisualElement, the root class of an fxg component, will notify its parent when its width/height or constraint styles have changed. This change will notify the parent when the x/y position, rotation or scale have changed. This fixes some issues with an fxg component properly participating in layout. Also, it fixes the tooling issue of receiving an update if the layout of the fxg component has changed.
      QE notes: Need to add tests for these use cases
      Doc notes: None
      Bugs: SDK-22453
      Reviewer: Ryan
      Tests run: spark/primitives
      Is noteworthy for integration: Yes. Fix is for Catalyst. Should not need any modifications to the Catalyst code.
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/core/SpriteVisualElement.as
