0 Replies Latest reply on Aug 4, 2009 1:42 PM by Chet Haase
    [svn:fx-trunk] 9073: Fixed a regression with Fade ( dealing with non-IVisualElementContainer parented objects, like Popup) and improved seeking behavior with repeatDelay on composite effects.
    Chet Haase
      Revision: 9073
      Author:   chaase@adobe.com
      Date:     2009-08-04 13:42:36 -0700 (Tue, 04 Aug 2009)
      Log Message:
      Fixed a regression with Fade (dealing with non-IVisualElementContainer parented objects, like Popup) and improved seeking behavior with repeatDelay on composite effects. Also improved effect seeking in general, though it's still not perfect.
      QE notes: Mustella failure of Sequence_seek_IntoRC2 is erroenous (the test bitmap is wrong, based on bad earlier behavior)
      Doc notes: None
      Bugs: SDK-22285, sdk-22555
      Reviewer: Jason
      Tests run: checkintests, Mustella (spark/effects, mx/effects)
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-22285
          http://bugs.adobe.com/jira/browse/sdk-22555
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/effectClasses/CompositeEffect Instance.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/effectClasses/ParallelInstanc e.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/effectClasses/SequenceInstanc e.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/AnimateTransform.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Fade.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/animation/Animation.as
