5 Replies Latest reply on Aug 11, 2009 8:34 AM by matthew horn
    PlotChart fillFunction
    paraglidersd Level 1
      I am using a fillFunction on a plotChart to determine which color the item should be.  Is there a way to determine which 'shape' and whether the drawn shape is color-filled or just outlined?  -Thanks,Bill
        • 1. Re: PlotChart fillFunction
          matthew horn Level 3
          You can determine whether the shape is filled or not by setting the returned IFill's alpha set to 0 (it's the second param in the SolidColor constructor). For example:
          private function myFillFunction(element:ChartItem, index:Number):IFill {
               // some logic here to specify a custom color
               var c:SolidColor = new SolidColor(myColor, 0);
               return c;
          To change shape of a data point within a series based on its values, I think you could extend the series' item renderer (such as CircleItemRenderer), but I don't have an example that I can show you.
          matt horn
          flex docs
          • 2. Re: PlotChart fillFunction
            Thanks for the response, Matt.  Unfortunately, setting the IFill alpha to zero makes it so that the data point doesnt display at all (meaning, its transparent?).  I want to draw, for example, the outline of a diamond and not have it filled in.  Maybe I did something wrong or misunderstood your post?
            • 3. Re: PlotChart fillFunction
              Ah, well, you can create a border around the diamon by setting the stroke, like this:
              <mx:SolidColor id="sc" alpha="0"/>
              <mx:Stroke id="s" color="0x000000" weight="1"/>
              Then in the series:
              fill="
              {sc}"
              stroke="
              {s}"
              hth,
              matt horn
              flex docs
              • 4. Re: PlotChart fillFunction
                Thank you.  I will try that.  If I am reading this right, I will have to have a different series for each 'type' of data I want to plot.  E.g., Some I want to be blue diamonds, some red circles, etc.   -Bill
                • 5. Re: PlotChart fillFunction
                  Well, yes and no. If you want to use different "item renderers" -- that is, different shapes for each "type" of data, then yes, you'll need a separate series. For example, if you were charting the condition of products, you could have a circle for products that are "new", a diamond for products that are "very good", and a box for products that are "poor" condition.
                  You can set the colors for each series (like a red circle) for the series without having to use a fill function. The fill function is if you want different colors of teh same "type" of items. Maybe your "new" product series would have red circles for items that are out of stock and green circles for items that are in stock, for example.
                  hth,
                  matt horn
                  flex docs
