0 Replies Latest reply on Aug 4, 2009 2:52 PM by Carol L. Frampton
    [svn:fx-trunk] 9080: RET no longer has a default maxWidth of 160.
    Carol L. Frampton
      Revision: 9080
      Author:   cframpto@adobe.com
      Date:     2009-08-04 14:52:25 -0700 (Tue, 04 Aug 2009)
      Log Message:
      RET no longer has a default maxWidth of 160.  That means that if a width is not specified then "toFit" text without explicit newlines will wrap at the default maxWidth of 10000.
      Selection on focusIn is implemented as follows.
      selection  selection        focusIn       multiline      !multiline
      before     set by           due to
      focusIn
      (-1, -1)   program          mouseDown     (m, m)         (m, m)
                                  tab           (0, 0)         select all
                                  program       (0, 0)         select all
      (5, 5)     mouse/keyboard   mouseDown     (m, m)         (m, m)
                                  tab           no change      select all
                                  program       no change      select all
      (5, 10)    mouse/keyboard   mouseDown     (m, m)         (m, m)
                                  tab           no change      no change
                                  program       no change      no change
      QE notes: since the focusIn change didn't break any TextArea/TextInput tests that means we don't have any
      Doc notes:
      Bugs:
      Reviewer: Alex
      Tests run: mustella TextInput TextArea passed
      Is noteworthy for integration: yes. No longer a default width for wrapping toFit text.
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/RichEditableText.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/RichEditable TextContainerManager.as
