0 Replies Latest reply on Aug 4, 2009 4:11 PM by Evtim Georgiev (Adobe)
    [svn:fx-trunk] 9091: Fix bug http://bugs.adobe.com/jira/browse/ SDK-22181 LayoutBoundsHeight and LayoutBoundWidth has rounding errors for rotated paths + optimizations
    Evtim Georgiev (Adobe) Level 2
      Revision: 9091
      Author:   egeorgie@adobe.com
      Date:     2009-08-04 16:11:37 -0700 (Tue, 04 Aug 2009)
      Log Message:
      Fix bug http://bugs.adobe.com/jira/browse/SDK-22181 LayoutBoundsHeight and LayoutBoundWidth has rounding errors for rotated paths + optimizations
      Fix: Path used to draw into a shape to determine the bounds, which had rounding error to the 1/20th of the pixel. Calculate the bounds directly by going through the segments instead - this yields full double precision.
      Additional changes:
      1. Reduce the number of dynamic Points allocated
      2. Remove the CloseSegment and replace it with a LineSegment
      3. Optimize the bounds() code to look at each line segment's points only once
      Additional changes bring 10% speed improvement in path layout over the trunk baseline for a test case of 5,000 star paths in a TileLayout (each with 9 line segments and 1 close segment).
      QE notes: None
      Doc notes: None
      Bugs: SDK-22181
      Reviewer: Jason
      Tests run: checkintests, gumbo/layout, graphicTags, gumbo/core/Group
      Is noteworthy for integration: Yes, bug SDK-22181 came from the Thermo team
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/utils/MatrixUtil.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/Path.as
