0 Replies Latest reply on Aug 5, 2009 3:25 AM by dam.C
    DataService Destination Clustering is  not working
    dam.C Level 1
      Hi All ,
      We are trying to get clustering configured for our application so that DataService's Destination keep serving  the cleint in case of any server failure .  We are using F5  hardware load balancer.
      We have set up a default-cluster, using tcp and  while creating DataService Destination we are setting cluster ID  as follows
      1)
                  DataNetworkSettings ns = new DataNetworkSettings();
                  ns.setPagingEnabled("false");
                  ns.setClusterId("default-cluster")
      2) service-config.xml
           <clusters>
              <cluster id="default-cluster" properties="jgroups-tcp.xml" url-load-balancing="false" />
            </clusters>
      3) jgroup-tcp.xml - First
          <TCP bind_addr="114.19.8.161"  start_port="7800" loopback="true" enable_diagnostics="true"/>
          <TCPPING timeout="3000" initial_hosts="114.19.8.226[7800]" port_range="1" num_initial_members="1"/>
          <MERGE2 min_interval="10000" max_interval="20000"/>
      3) jgroup-tcp.xml - Seond
          <TCP bind_addr="114.19.8.226"  start_port="7800" loopback="true" enable_diagnostics="true"/>
           <TCPPING timeout="3000" initial_hosts="114.19.8.161[7800]" port_range="1" num_initial_members="1"/>
      I am using Jboss4.2.2 GA and LCDS2.6.1and we have licenced version of LCDS
      I am getting following message on JBoss console : -
      04:26:15,296 INFO  [STDOUT] [Flex]Cluster node from address 114.19.8.161:7800 joined the cluster for default-cluster
      04:26:15,718 INFO  [JBossCacheManager] Starting JBossManager
      04:26:15,734 INFO  [TreeCache] received the state (size=1024 bytes)
      04:26:15,750 INFO  [TreeCache] received the state (size=8192 bytes)
      04:26:15,765 ERROR [TreeCache] failed setting transient state
      java.lang.ClassCastException: org.jboss.cache.loader.NodeData
              at org.jboss.cache.statetransfer.StateTransferIntegrator_140.integrateTransientSta te(StateTransferIntegrator_140.java:210)
              at org.jboss.cache.statetransfer.StateTransferIntegrator_140.integrateTransientSta te(StateTransferIntegrator_140.java:100)
      Am I  missing anything  ?
      During the testing when I bring down one of the jboss server, It immediately throws Destination  does not exist error
      I will appeciate any help on this .
      Dharmendra
      Regards,
      Dharmendra Chouhan
      Synechron Technologies
      Work: +91 - 20 - 4026 2000 (Ext: 2030)
      VOIP: 732 579 2080
      Cell: +91 -9850982613
      Working Hours: 02:30 am - 11:30 am EST
