1 Reply Latest reply on Aug 5, 2009 11:40 AM by SuperMacGuy
    AppleScript InDesign Document Save as
    FKlaes
      Hello @ All!
      I tried my first AppleScript. I tried to open a document and use "save as" (without dialog) to save the opened file in a new place and with a new name.
      in case of question: i have to use indesign for a convert of the format.
      Here is my Code-Snippet: (the part mentioned in the SDK failed!)
      tell application "Adobe InDesign CS4"
      set myDocument to open "Mac:IDS:InD-Files:delete_Test.indd"
      if saved of active document is true then
      tell active document to save saving in "Mac:IDS:test.indd" --speichern ohne save-dialog
      end if
      close document 1 --Dokument schließen
      --end repeat --ende der schleife
      display dialog "Alle Dateien bearbeitet"
      end tell
      After Running i get the failure message:
      „saving of "Mac:IDS:test.indd"“ kann nicht gelesen werden."
      cannot read this path or file.
      The path exists.
      What am i doing wrong? or where is the mistake!
      Thanks for your help.
      Kind regards
