14 Replies Latest reply on Aug 5, 2009 12:54 PM by gnaigaonkar
    Regarding dynamically loading slider/radios within grid
    gnaigaonkar
      I have a DataGrid and I am using ItemRenderers to dynamically load components like images and buttons within it. Now, I wanted to know if its possible to load a slider or even a radiogroup based on values that the datagrid receives dynamically. If a slider is used it needs to be calibrated with data that it receives from dataprovider property of the grid. Similarly, if a radio group is used, I should be able to render number of radios depending on the data provided to datagrid.
      I am basically building an application for image search where I want to provide a slider or radios (within each row of datagrid) displaying various sizes in which the same image is available. The user should be able to select a size and then further processing continues.
      Let me know if this is possible.Thanks.
