5 Replies Latest reply on Aug 6, 2009 10:14 AM by kglad
    show images in a swf file
    birtlet
      Hi all,
      I'm new of flash.
      I'm creating a web site using adobe flash cs4.
      I need to insert an images slideshow but i have a problem and I cannot understand what is the solution.
      I import in my library many images which I put into a layer after converting them to a movieclip.
      When I press enter I can see the images but when I press test movie i cannot see them.
      Can anyone help me?
      Thanks a lot in advance
      birtlet
        • 1. Re: show images in a swf file
          are you using a mask?  are you using any actionscript?  are you assigning any movieclip properties (like an alpha) after place the movieclips on-stage?
          • 2. Re: show images in a swf file
            birtlet Level 1
            I'm sorry if I was not clear and not exahustive.
            1. I' using a mask but I think it isn't a problem since when I press enter I can see the picture in a correct way
            2. I'm usign a simple action script to stop the movie at the last frame and to show two button
                ( w.r.t. this I'd like to ask to you how, with the action script, I can refer to an object created into the stage. I try through is reference name but it doesn't work)
            3. After placing the movie clip into the stage I assigned alpha properties to the movie-clip. in particular I Have transformed the images into movie-clips and then after creating a motion tween i set the alpha properties.
            I Hope to be exausistive. Anyway I cannot attach here my .fla It is too big (64 MB). I don't know how i can give you my source code. If you know, please tell me.
            Thanks a lot.
            • 3. Re: show images in a swf file
              i generally don't download and correct files unless i'm hired to do so.
              and i don't understand what you're doing so i can't help.  perhaps someone else will be able to understand and help you.
              • 4. Re: show images in a swf file
                birtlet Level 1
                I'm sorry...
                but I think that forums born to share knowledge, maybe this is not the same for you... no problems... next time I'll send you a payment
                but now I think that I'll found people that share my idea and will be happy first to understand me and then to help.
                Thanks a lot... again
                • 5. Re: show images in a swf file
                  you're welcome.
