1 Reply Latest reply on Jul 29, 2008 3:47 PM by benwgemex
    Unable to get simple DataService to work
    benwgemex
      Hi, I have been trying to get a simple DataService prototype to work. I am using Flex DS 2.6 (the latest) with JBoss 4.0.3sp1 server. I have a very simple MXML application as follow:
      <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" layout="vertical">
      <mx:DataService id="fooService" destination="fooAssembler" result="getAllHandler(event)"/>
      <mx:Script>
      <![CDATA[
      import mx.rpc.events.ResultEvent;
      import com.gemex.Foo;
      [Bindable]
      private var foo:Foo;
      private function getAllHandler(event:ResultEvent):void {
      foo = event.result as Foo;
      </mx:Script>
      <mx:TextInput id="fooId"/>
      <mx:Button label="Retrieve" click="fooService.getItem({id: int(fooId.text)})"/>
      <mx:TextInput id="fooName" text="{foo.name}"/>
      </mx:Application>
      The server side configuration is as follow:
      In data-management-config.xml, I have added the following:
      <destination id="fooAssembler">
      <adapter ref="java-dao"/>
      <properties>
      <source>fooAssembler</source>
      <factory>spring</factory>
      <metadata>
      <identity property="id"/>
      </metadata>
      </properties>
      <channels>
      <channel ref="my-rtmp"/>
      </channels>
      </destination>
      <factories>
      <factory id="spring" class="com.gemex.arch.flex.factories.SpringFactory"/>
      </factories>
      When I run the sample, I get the following message in the browser:
      [RPC Fault faultString="There was an unhandled failure on the server. null" faultCode="Server.Processing" faultDetail="null"]
      at mx.data::ConcreteDataService/ http://www.adobe.com/2006/flex/mx/internal::dispatchFaultEvent()[C:\depot\flex\branches\en terprise_corfu_rc\frameworks\projects\data\src\mx\data\ConcreteDataService.as:2550
      at DataListRequestResponder/fault()[C:\depot\flex\branches\enterprise_corfu_rc\frameworks\pr ojects\data\src\mx\data\ConcreteDataService.as:7349]
      at mx.rpc::AsyncRequest/fault()[E:\dev\3.0.x\frameworks\projects\rpc\src\mx\rpc\AsyncRequest .as:103]
      at NetConnectionMessageResponder/statusHandler()[E:\dev\3.0.x\frameworks\projects\rpc\src\mx \messaging\channels\NetConnectionChannel.as:523]
      at mx.messaging::MessageResponder/status()[E:\dev\3.0.x\frameworks\projects\rpc\src\mx\messa ging\MessageResponder.as:222]
      I also got a bunch of output from the JBoss console, but it is too long to list here. Let me know if that would help. I was able to make a similar example work with the LCDS 2.5. I have been banging my head for over 3 days now. Hope someone has some insight as to what I should try next.
      Thanks much,
      Ben
        • 1. Re: Unable to get simple DataService to work
          benwgemex Level 1
          In case the JBoss console output is useful, here is the output from the LCDS classes:
          17:44:47,898 INFO [STDOUT] [LCDS] Thread[my-rtmp-SocketServer-Reactor1Writer,5,jboss] Connection '20633739' starting a write.
          17:44:47,898 INFO [STDOUT] [LCDS] Thread[my-rtmp-SocketServer-Reactor1Writer,5,jboss] Connection '20633739' finished a write. 33 bytes were
          written.
          17:44:47,898 INFO [STDOUT] [LCDS] Thread[my-rtmp-SocketServer-WorkerThread-1,5,jboss] received message TCMessage [ Type: MsgCmd, Stream ID:
          0]
          17:44:48,149 INFO [STDOUT] [LCDS] Deserializing AMF/RTMP request
          Version: 0 "connect"
          1.0
          (Command method=connect (2) trxId=1.0)
          (Object #0)
          app = ""
          flashVer = "WIN 9,0,124,0"
          swfUrl = " http://localhost:8080/template/FooDataServiceTest-debug/FooDataServiceTest2.swf"
          tcUrl = "rtmp://localhost:2038"
          fpad = false
          capabilities = 15.0
          audioCodecs = 1639.0
          videoCodecs = 252.0
          videoFunction = 1.0
          pageUrl = " http://localhost:8080/template/FooDataServiceTest-debug/FooDataServiceTest2.html"
          objectEncoding = 3.0
          false
          "nil"
          (Typed Object #1 'flex.messaging.messages.CommandMessage')
          operation = 5.0
          correlationId = ""
          body = (Object #2)
          messageId = "3ACAC242-854B-7040-EEFB-70FEB89ED9F9"
          clientId = null
          destination = ""
          timeToLive = 0.0
          headers = (Object #3)
          DSMessagingVersion = 1.0
          DSId = "my-rtmp"
          timestamp = 0.0
          17:44:48,149 INFO [STDOUT] [LCDS] Received command: TCCommand [ Cmd: 2, MethodName: connect, TrxID: 1.0]
          17:44:48,209 INFO [STDOUT] [LCDS] Serializing AMF/RTMP response
          Version: 0
          (Command method=_result (0) trxId=1)
          (Object #0)
          id = "FEDDF1EB-990B-626C-FBA1-24DBDF9563FC"
          level = "status"
          details = null
          description = "Connection succeeded."
          code = "NetConnection.Connect.Success"
          17:44:48,209 INFO [STDOUT] [LCDS] Thread[my-rtmp-SocketServer-WorkerThread-1,5,jboss] registering write interest for Connection '20633739'.
          17:44:48,209 INFO [STDOUT] [LCDS] Thread[my-rtmp-SocketServer-Reactor1,5,jboss] unregistering write interest for Connection '20633739'.
          17:44:48,209 INFO [STDOUT] [LCDS] Thread[my-rtmp-SocketServer-Reactor1Writer,5,jboss] Connection '20633739' starting a write.
          17:44:48,209 INFO [STDOUT] [LCDS] Thread[my-rtmp-SocketServer-Reactor1Writer,5,jboss] Connection '20633739' finished a write. 235 bytes wer
          e written.
          17:44:48,209 INFO [STDOUT] [LCDS] Thread[my-rtmp-SocketServer-WorkerThread-1,5,jboss] registering read interest for Connection '20633739'.
          17:44:48,219 INFO [STDOUT] [LCDS] Thread[my-rtmp-SocketServer-WorkerThread-1,5,jboss] Connection '20633739' finished a read. 2226 bytes wer
          e read.
          17:44:48,229 INFO [STDOUT] [LCDS] Thread[my-rtmp-SocketServer-Reactor1,5,jboss] unregistering read interest for Connection '20633739'.
          17:44:48,229 INFO [STDOUT] [LCDS] Thread[my-rtmp-SocketServer-WorkerThread-1,5,jboss] Connection '20633739' starting a read.
          17:44:48,229 INFO [STDOUT] [LCDS] Thread[my-rtmp-SocketServer-WorkerThread-1,5,jboss] received message TCMessage [ Type: MsgCmdEx, Stream I
          D: 0]
          17:44:48,239 INFO [STDOUT] [LCDS] Deserializing AMF/RTMP request
          Version: 3 null
          2.0
          (Command method=null (0) trxId=2.0)
          null
          (Typed Object #0 'flex.messaging.messages.CommandMessage')
          operation = 5
          correlationId = ""
          body = (Object #1)
          messageId = "E4D9CF52-2AD1-6A5F-E895-70FEBFDBE7B2"
          clientId = null
          destination = "fooAssembler"
          timeToLive = 0
          headers = (Object #2)
          DSEndpoint = "my-rtmp"
          DSId = "FEDDF1EB-990B-626C-FBA1-24DBDF9563FC"
          timestamp = 0
          17:44:48,239 INFO [STDOUT] [LCDS] Received command: TCCommand [ Cmd: 0, MethodName: null, TrxID: 2.0]
          17:44:48,249 INFO [STDOUT] [LCDS] Serializing AMF/RTMP response
          Version: 3
          (Command method=_result (0) trxId=2.0)
          (Externalizable Object #0 'DSK')
          true
          (Object #1)
          1.217371488239E12
          (Byte Array #2, Length 16)
          (Byte Array #3, Length 16)
          (Byte Array #4, Length 16)
          17:44:48,249 INFO [STDOUT] [LCDS] Thread[my-rtmp-SocketServer-WorkerThread-1,5,jboss] registering write interest for Connection '20633739'.
          17:44:48,249 INFO [STDOUT] [LCDS] Thread[my-rtmp-SocketServer-Reactor1,5,jboss] unregistering write interest for Connection '20633739'.
          17:44:48,249 INFO [STDOUT] [LCDS] Thread[my-rtmp-SocketServer-WorkerThread-1,5,jboss] received message TCMessage [ Type: MsgCmdEx, Stream I
          D: 0]
          17:44:48,249 INFO [STDOUT] [LCDS] Deserializing AMF/RTMP request
          Version: 3 null
          3.0
          (Command method=null (0) trxId=3.0)
          null
          (Externalizable Object #0 'flex.data.messages.DataMessageExt')
          "fooAssembler"
          (Object #1)
          (Object #4)
          id = 2
          2
          17:44:48,279 INFO [STDOUT] [LCDS] Received command: TCCommand [ Cmd: 0, MethodName: null, TrxID: 3.0]
          17:44:48,249 INFO [STDOUT] [LCDS] Thread[my-rtmp-SocketServer-Reactor1Writer,5,jboss] Connection '20633739' starting a write.
          17:44:48,279 INFO [STDOUT] [LCDS] Thread[my-rtmp-SocketServer-Reactor1Writer,5,jboss] Connection '20633739' finished a write. 183 bytes wer
          e written.
          17:44:48,389 INFO [STDOUT] [LCDS] Committed transaction
          17:44:48,409 INFO [STDOUT] [LCDS] Serializing AMF/RTMP response
          Version: 3
          (Command method=_error (0) trxId=3.0)
          (Typed Object #0 'flex.messaging.messages.ErrorMessage')
          headers = (Object #1)
          rootCause = null
          body = null
          correlationId = "2074DF18-D2EA-03D2-6E54-70FEB8948E49"
          faultDetail = null
          faultString = "There was an unhandled failure on the server. null"
          clientId = "F0223A68-BD80-ED4B-1390-70FEB1B1128E"
          timeToLive = 0.0
          timestamp = 1.217371488399E12
          extendedData = null
          faultCode = "Server.Processing"
          messageId = "FEDDF41D-1F0A-A0D7-9DED-D7D7AB39AF51"
          17:44:48,409 INFO [STDOUT] [LCDS] Thread[my-rtmp-SocketServer-WorkerThread-1,5,jboss] registering write interest for Connection '20633739'.
