0 Replies Latest reply on Aug 5, 2009 5:11 PM by Jason Szeto
    [svn:fx-trunk] 9124: http://bugs.adobe.com/jira/browse/ SDK-22488 - Odd bitmap sharing issue with custom DropDownList component using bitmap item renderer
    Jason Szeto Level 3
      Revision: 9124
      Author:   jszeto@adobe.com
      Date:     2009-08-05 17:11:14 -0700 (Wed, 05 Aug 2009)
      Log Message:
      http://bugs.adobe.com/jira/browse/SDK-22488 - Odd bitmap sharing issue with custom DropDownList component using bitmap item renderer
      BitmapImage was disposing of the previous source whenever a new source was set. Since the button BitmapImage was always swapping in the selectedItem, it destroyed the previously selected item.
      The fix is to alter the code that disposes of the old source. If the BitmapImage created the BitmapData (because the source was a Class or DisplayObject), then it is responsible for disposing of it. Otherwise it is the developer's responsibility to dispose of the BitmapData.
      I updated the ASDoc to explain when BitmapImage will dispose of the BitmapData.
      QE notes: Add test cases
      Doc notes: Need to explain when the developer is responsible for disposing of the BitmapData.
      Bugs: SDK-22488
      Reviewer: Glenn
      Tests run: spark primitives
      Is noteworthy for integration: No
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/BitmapImage.as
