0 Replies Latest reply on Aug 5, 2009 6:19 PM by kyser777
    Problem, change the language with dynamic text
    kyser777
      I am looking for a way to change simply the language of my flash animation
      I work with flash cs4
      of course I got Mylocale.as:
      import mx.lang.Locale;
      class MyLocale extends mx.lang.Locale {
      static function start():Void {
      var langCode:String = xmlLang;
      currentXMLMapIndex = 0;
      xmlDoc.load(xmlMap[langCode][0]);
      static function setXMLLang(langCode:String):Void {
      xmlLang = langCode;
      and different xml files in the same folder than my swf file
      in string , I ticked : "replace  strings automatically during the execution"
        with a default language (I am wondering if the problem is not from there)
        if I tick: "replace strings manually using the scene language " or "replace strings via actionscript"
      my code does not work.
        then I kept: "replace strings automatically during the execution"
      in my flash animation I have several scenes (pages)
      p1, p2, p3, p4
      in p1
      I created a language bar
      then 2 layers inside
      Layer--action:
      langListener = new Object();
      langListener.change = function(eventObj) {
      var target = eventObj.target;
      var newLang = target.selectedItem.data;
      MyLocale.setXMLLang(newLang);
      MyLocale.start();
      lang_cb.addEventListener("change", langListener);
      // Force Japanese
      lang_cb.selectedIndex = 1;
      lang_cb.dispatchEvent({type:"change"});
      Layer--language ex Fr:
      // Forces combobox to have the correct value
      on (release) {
      var component = _parent.lang_cb;
      for (var i=0; i< component.length; i++) {
      var item = component.getItemAt(i);
      if (item.data == "fr") {
      component.setSelectedIndex(i);
      component.dispatchEvent({type:"change"});
      break;
      ex Ja :
      on (release) {
      if (item.data == "ja") {
      break;
      When I change the language in p1 , the language is also modified in p2, p3 and p4
      however , after a navigation in p2, p3 and p4 , once I come back in p1 , the default language is back automatically although I did not touch the language bar!!
      I don't know how to solve the problem
      to my mind , the script reset itself each time I come back on p1
      is there a way to keep the saved settings even when I am back on p1 until I modify manually again the language bar
      thanks a lot
