1 Reply Latest reply on Aug 5, 2009 11:05 PM by Mainmanian
    FLVPlayback component in Flex
    Mainmanian Level 1
      I am having a very hard time playing my flv files in videoDisplay thru an http url as the source. I am not sure if taht is because my FLV files have a lot of NetStream commands embedded in them, but they all play without video (the screen is just black). I am however able to paly taht in flash using FLVPlayback component. Does ayone know if there is a way to use that component in Flex, somehting that I could drag like a videoDisplay or similarly simpel manner? Thanks
        • 1. Re: FLVPlayback component in Flex
          Gregory Lafrance Level 6
          Here are some things to check:
          1) -use-network=true       Project - Properties - Flex Compiler - Additional compiler arguments, add -use-network=true
          2) Verify that the relative paths to the video files are correct on the server.
          3) Could be a timing issue. If the video is not streaming and its not loaded yet, black screen could be the result.
          If this post answers your question or helps, please mark it as such.
