3 Replies Latest reply on Aug 11, 2009 1:40 AM by Gabriel Z
    Improvements to gradients.
    Gabriel Z
      I suggested this before but since its gone in the new forum here it is again:
      Gradient improvements.
      Adjust the hue/saturn/Brightness contrast of a gradient.
      Like in Sumopaint.
      I use gradients daily and this would be a huge timesaver.
      When working with complex gradients, its very akward to adjust all of their colors individually.
      Should be easy to implement.
      Repeat to every X pixels or X number of times.
      Interactive gradient lines like in illustrator. For gradient effects.
      But also with interactive repeat markers. that would let you change the position of one or more repeat markers to make it repeat nolinear.
      Please add a new gradient type:
      Eliptical gradient.
      Like in Inkscape. Very useful.
        • 1. Re: Improvements to gradients.
          c.pfaffenbichler Level 9
          Well, I think a Hue/Saturation-Adjustment Layer clipping masked to the Gradient-Layer might be good enough as it is.
          That I would agree would be an improvement.
          Eliptical gradient.
          I’m not familiar with Inkscape, so I don’t know what features that would include (perspectival shortening?), but it might be more convenient that the work-around with Smart Objects.
          • 2. Re: Improvements to gradients.
            Level 7
            How do you propose defining the ellipse for elliptical gradients?
            • 3. Re: Improvements to gradients.
              Gabriel Z Level 1
              I imagine it as there would be two ways to create the eliptical gradient.
              One for layer FX and one for the gradient tool.
              The layer FX, could work as the circular/eliptical gradient in inkscape. With control handels for direction/center and width. With the addition of repeats.
              The gradient tool could work as a twostep rocket. Many 3d programs work this way when you create a new object.
              1. First you drag the direction and length from the center. (Or hold alt to drag from the corner?)
              2. When you release the button the mouse will adjust the width. When you press the button the second time it will apply the gradient.
              "Well, I think a Hue/Saturation-Adjustment Layer clipping masked to the Gradient-Layer might be good enough as it is."
              It doesn't work in every case and its also requires you to allways copy and remake the layermask when applying the gradient to another object on another layer.
              For example: When you apply a gradient FX inside a object together with other effects such as innerglow or a pattern. An adjustment layer would also change the color of all the other effects.
