I am using this code to convert html to pdf.
* 1. adobe-generatepdf-client.jar
* 2. adobe-livecycle-client.jar
* 3. adobe-usermanager-client.jar
* 4. adobe-utilities.jar
* 5. wlclient.jar
import java.io.File;
import java.util.Properties;
import com.adobe.idp.Document;
import com.adobe.idp.dsc.clientsdk.ServiceClientFactory;
import com.adobe.idp.dsc.clientsdk.ServiceClientFactoryProperties;
import com.adobe.livecycle.generatepdf.client.GeneratePdfServiceClient;
import com.adobe.livecycle.generatepdf.client.HtmlToPdfResult;
public class ConvertHTML {
public static void main(String[] args)
try{
//Set connection properties required to invoke LiveCycle ES
Properties connectionProps = new Properties();
connectionProps.setProperty(ServiceClientFactoryProperties.DSC_DEFAULT_EJB_ENDPOINT, "t3://localhost:7001");
connectionProps.setProperty(ServiceClientFactoryProperties.DSC_TRANSPORT_PROTOCOL,ServiceClientFactoryProperties.DSC_EJB_PROTOCOL);
connectionProps.setProperty(ServiceClientFactoryProperties.DSC_SERVER_TYPE, "WebLogic");
connectionProps.setProperty(ServiceClientFactoryProperties.DSC_CREDENTIAL_USERNAME, "administrator");
connectionProps.setProperty(ServiceClientFactoryProperties.DSC_CREDENTIAL_PASSWORD, "password");
//Create a ServiceClientFactory instance
ServiceClientFactory factory = ServiceClientFactory.createInstance(connectionProps);
//Create a GeneratePdfServiceClient object
GeneratePdfServiceClient pdfGenClient = new GeneratePdfServiceClient(factory);
//Get an HTML document to convert to a PDF document a
String inputFileName = "http://www.adobe.com";
//String inputFileName = "C:\\Documents and Settings\\venkat\\Desktop\\Adobe.htm";
String securitySettings = "No Security";
String fileTypeSettings = "Standard";
System.out.println("one");
//Convert HTML content to a PDF document
HtmlToPdfResult result = pdfGenClient.htmlToPDF2(inputFileName, fileTypeSettings, securitySettings, null, null);
System.out.println("two");
//Get the newly created document
Document createdDocument = result.getCreatedDocument();
//Save the PDF document as a PDF file
createdDocument.copyToFile(new File("C:\\test.pdf"));
catch (Exception e) {
System.out.println("Error OCCURRED: " + e.getMessage());
e.printStackTrace();
I can able to compile this class but while running i am getting error like below.
Error OCCURRED: Internal error.
ALC-DSC-000-000: com.adobe.idp.dsc.DSCRuntimeException: Internal error.
at com.adobe.idp.dsc.provider.impl.ejb.EjbMessageDispatcher.doSend(EjbMessageDispatcher.java
:160)
at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(AbstractMessageDispat
cher.java:57)
at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:208)
at com.adobe.livecycle.generatepdf.client.GeneratePdfServiceClient.htmlToPDF2(GeneratePdfSer
viceClient.java:666)
at ConvertHTML.main(ConvertHTML.java:84)
Caused by: java.rmi.RemoteException: Remote EJBObject lookup failed for 'ejb/Invocation'; nested exc
eption is:
org.omg.CORBA.COMM_FAILURE: vmcid: SUN minor code: 203 completed: No
at com.adobe.idp.dsc.provider.impl.ejb.EjbMessageDispatcher.initialise(EjbMessageDispatcher.
java:101)
:130)
... 4 more
Caused by: org.omg.CORBA.COMM_FAILURE: vmcid: SUN minor code: 203 completed: No
at com.sun.corba.se.impl.logging.ORBUtilSystemException.writeErrorSend(Unknown Source)
at com.sun.corba.se.impl.transport.SocketOrChannelConnectionImpl.writeLock(Unknown Source)
at com.sun.corba.se.impl.encoding.BufferManagerWriteStream.sendFragment(Unknown Source)
at com.sun.corba.se.impl.encoding.BufferManagerWriteStream.sendMessage(Unknown Source)
at com.sun.corba.se.impl.encoding.CDROutputObject.finishSendingMessage(Unknown Source)
at com.sun.corba.se.impl.protocol.CorbaMessageMediatorImpl.finishSendingRequest(Unknown Sour
ce)
at com.sun.corba.se.impl.protocol.CorbaClientRequestDispatcherImpl.marshalingComplete1(Unkno
wn Source)
at com.sun.corba.se.impl.protocol.CorbaClientRequestDispatcherImpl.marshalingComplete(Unknow
n Source)
at com.sun.corba.se.impl.protocol.CorbaClientDelegateImpl.invoke(Unknown Source)
at com.sun.corba.se.impl.protocol.CorbaClientDelegateImpl.is_a(Unknown Source)
at org.omg.CORBA.portable.ObjectImpl._is_a(Unknown Source)
at weblogic.corba.j2ee.naming.Utils.narrowContext(Utils.java:126)
at weblogic.corba.j2ee.naming.InitialContextFactoryImpl.getInitialContext(InitialContextFact
oryImpl.java:94)
oryImpl.java:31)
at weblogic.jndi.WLInitialContextFactory.getInitialContext(WLInitialContextFactory.java:41)
at javax.naming.spi.NamingManager.getInitialContext(Unknown Source)
at javax.naming.InitialContext.getDefaultInitCtx(Unknown Source)
at javax.naming.InitialContext.init(Unknown Source)
at javax.naming.InitialContext.<init>(Unknown Source)
at com.adobe.idp.dsc.provider.impl.ejb.EjbMessageDispatcher.initJndiContext(EjbMessageDispat
cher.java:213)
at com.adobe.idp.dsc.provider.impl.ejb.EjbMessageDispatcher.getJndiContext(EjbMessageDispatc
her.java:226)
java:87)
... 5 more
can u plz give me some way to do the convertion.
Views
Total Likes
