1 Reply Latest reply on Aug 6, 2009 9:48 AM by acath
    Flex 3 + catalyst
    V.K.R (Vijay)
      Is it possible to integrate a file to the Flex 3  which was designed in adobe catalyst ?
        • 1. Re: Flex 3 + catalyst
          acath Level 4
          Check out Joan's whitepaper on Flex 3 to 4 migration: http://www.adobe.com/devnet/flex/articles/flex3and4_differences.html
          In my cursory understanding of this issue, there are 2 ways to do what you're trying to do:
          1.  (Preferred, slightly more overhead) Switch your project to a Flex 4 project.
          •   You can still use the exact same Flex 3 code, but compile it with the Flex 4 SDK.
          •   Probably the easiest way to do this is to open your project in Flash Builder 4 Beta, then change the SDK from project properties > Flex Compiler
          •   Embed your Catalyst-created SWF using SWFLoader or Image, in the normal fashion. You should set loadForCompatibility="true"
          2.  (Easier, but not really supported) Keep your project as a Flex 3 project, but update some properties.
          •   In project properties > Flex Compiler, make sure you are using at least SDK 3.2 - this is the first version that supports loading Flex 4 content inside a Flex 3 app.
          •   In project properties > Flex Compiler, change the "Require Flash Player version" to 10.0.0.
          •   Embed your Catalyst-created SWF using SWFLoader or Image, in the normal fashion. You should set loadForCompatibility="true".
          Let me know if you need more details. You can probably get a more complete response on the Flex 4 beta forums ( http://forums.adobe.com/community/opensource/flexsdk/general ).
          -Adam
