1. Re: Floating issue
Zabeth69 Aug 6, 2009 12:48 PM (in response to upstart1762)Hi, Up,
Can you upload the file so we can take a look at the code in action?
Take a look at your img dimensions. Have you set the gray-backgrounded <div> with Overflow: hidden; ? That should keep the <div> from trying to expand when you insert the image. Watch out for margins and padding on the image.
Have you tried inserting just html? Presumably it does not break then.
Z
2. Re: Floating issue
upstart1762 Aug 6, 2009 1:01 PM (in response to Zabeth69)While I was waiting I cleared out the divs and the css, and I rebuilt. And now it is working. See attached. I'm new to this. Are these files still very quirky and prone to corruption? Because I had the exact same code in the old version.
I've also been playing with positioning using absolute positioning (inside a "relatively-positioned container). Do most developers prefer floating or using "positioning"? Each seems to present its own special problems.
3. Re: Floating issue
Zabeth69 Aug 6, 2009 1:11 PM (in response to upstart1762)There are many tools in a developer's toolbox. Sometimes one tool seems more appropriate, sometimes another.
Your best bet is to learn both and make your own choice, depending on how it will be used. I think a lot of how code is used ties in with the way you are thinking about the site you are building, how you have conceptualized it, and the pieces you are fitting together to build it, and those are perforce quite individual, developer to developer.
An unnoticed unclosed CSS statement or an extra space where it doesn't belong can break code.
I think you handled it correctly by deleting and rewriting. It's a much cleaner approach than to try to jigger code that has an error in it somewhere.
You should also make use of Validation tools to help check your code for you. There's one integral to Dreamweaver, and many developers also use Validator tools on the Web.
Z
4. Re: Floating issue
upstart1762 Aug 6, 2009 1:25 PM (in response to Zabeth69)I'm sure you are right. Seems that each approach comes with its own pitfalls and risks - one solution presents a series of subsequent challenges and chain reactions. I should be bald by September. Thanks!
