2 Replies Latest reply on Aug 4, 2008 6:23 PM by Gregory Lafrance
    Refer application window
    from-kriftel
      Hi Everybody
      I would like to know how can I access main application window from my custom classes to <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" layout="absolute" width="1000" height="1000" creationComplete="loadComponents()" > to be precise
      I have a class called TplElement in which I have a function called createPhysicalElement which adds up canvas to the main application window after parsing an XML file
      public class TplElement
      private var _id:int = 0;
      private var _name:String = "";
      private var _type:String = "";
      private var _properties:TplElementProperty;
      public function TplElement(id:int, name:String, propertyType:String, properties:Array)
      _id = id;
      _name = name;
      _type = propertyType;
      _properties = new TplElementProperty(properties);
      public function getElementProperties():TplElementProperty
      return _properties;
      public function createPhysicalElement():Canvas{
      var xmlCanvas:Canvas = new Canvas();
      xmlCanvas.x = int(_properties.get("left",0));
      xmlCanvas.y = int(_properties.get("top",0));
      xmlCanvas.width = int(_properties.get("width",0));
      xmlCanvas.height = int(_properties.get("height",0));
      xmlCanvas.setStyle("backgroundColor", String(_properties.get("background-color",0)));
      xmlCanvas.visible = true;
      xmlCanvas.id = String(_id);
      xmlCanvas.name = String(_name);
      addChild(xmlCanvas);
      return xmlCanvas;
      This somehow does not works can anyone help please
        • 1. Re: Refer application window
          Level 7
          "from-kriftel" <webforumsuser@macromedia.com> wrote in message
          news:g6n03g$jc5$1@forums.macromedia.com...
          > Hi Everybody
          > custom
          > after
          > parsing an XML file
          > properties:Array)
          > _id = id;
          > _name = name;
          > return _properties;
          > return xmlCanvas;
          Sounds like you'd be better off using a repeater. But to answer your
          question, look at outerDocument.
          HTH;
          Amy
          • 2. Re: Refer application window
            Gregory Lafrance Level 6
            Or you might try
            parent.ParentVarOrMethod
            or
            Application.application.ParentVarOrMethod
            in this case don't forget to
            import mx.core.Application;
