2 Replies Latest reply on Aug 10, 2009 7:35 AM by domflexdom
    Strings to displayObject
    domflexdom
      Hello,
      I need to populate combo box with an ArrayCollection that contains mutiple values.
      I have done a loop in wich every value of type String can be attributed.
      Though, to populate the combo box i can only use the method addChild
      myComboBox.addChild(child:DisplayObject):DisplayObject.
      how can I pass a string to some DisplayObject.
      OR , is there another way to populate a combo box using Strings ?
      remember that i'm in the  <mx:Script><![CDATA[ ]]><!/mx:Script>
      tag, which means that i can't simply use the <mx:array> <mx:String>value</mx:String></mx:array> tags
      any ideas ?
      thanks
      dom
        • 1. Re: Strings to displayObject
          Gregory Lafrance Level 6
          You never use addChild to populate a ComboBox:
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
            creationComplete="init();">
            <mx:Script>
              <![CDATA[
               import mx.controls.ComboBox;
                import mx.collections.ArrayCollection;
                [Bindable] private var ac:ArrayCollection = new ArrayCollection([
                  "one", "two", "three", "four"
                private function init():void{
                  var cbx:ComboBox = new ComboBox();
                  cbx.dataProvider = ac;
                  hb.addChild(cbx);
            </mx:Script>
            <mx:HBox id="hb">
              <mx:ComboBox dataProvider="{ac}"/>
            </mx:HBox>
          </mx:Application>
          If this post answered your question or helped, please mark it as such.
          • 2. Re: Strings to displayObject
            domflexdom Level 1
            Actually, i fixed my problem by filling an array from a determined field from my arrayCollection. And i used that new array as a dataprovider for my dropBoxes.
            The array is created each time the program request a newer version of the database's query.
