2 Replies Latest reply on Aug 7, 2009 11:24 AM by Chet Haase
    play effect on dynamically created visual component
    _luke_*
      Hi!
      Can someone please explain to me, how do I play effect on a visual component created in actionscript?
      Thanks, regards
        • 1. Re: play effect on dynamically created visual component
          David_F57 Level 5
          _luke_* wrote:
          Hi!
          Thanks, regards
          It depends on what you are try to do, if you want for instance a mouse over affect you can add the effect at the same time you create the component by adding an event listener which then plays the effect.
          ie.
          var myComponent: SpecialComponent = new SpecialComponent()
          myComponent.addEventListener(MouseEvent.MOUSE_OVER, runEffect);
          private function runEffect(event:MouseEvent): void
            myEffect.play(event.currentTarget);
          • 2. Re: play effect on dynamically created visual component
            Chet Haase Level 3
            You can also set the target/targets property of the effect once you've created the instance in AS, just like you do in MXML code. So where in MXML you might have something like this:
                 <mx:Button id="button" click="mover.play()"/>
                  <mx:Move id="mover" target=""/>
            you would do the equivalent in actionscript like this:
                 var button:Button = new Button();
                 var mover:Move = new Move();
                 mover.target = button;
                 button.addEventListener(MouseEvent.CLICK, clickHandler);
                 private function clickHandler(event:Event):void
                      mover.play();
            There's no mystery here in launching effects from AS - it's the same properties and structures that you set up in MXML, just different syntactic ways of referring to the properties and events.
            Chet.
