2 Replies Latest reply on Aug 7, 2009 9:00 AM by jimmyoneshot
    Bizarre TileList problem in AIR that doesn't appear in Flex version
    jimmyoneshot Level 1
      In my application I have some drag and drop tilelist's however I have only just discovered that if I attempt to drag an item in any of the tilelists and drop it directly onto, or usually slightly just below itself i get a very strange error:-
      "Error #1009: Cannot access a property or method of a null object reference."
      The bizzare thing is this exact code works fine within a flex application but the error gets produced within an AIR app. It's the only error I get in my whole application so it's a complete nightmare. One thing I've noticed is that if you drop an item onto itself within Flex a sort of zoom animation of the item occurs but this same animation doesn't sem to occur in AIR apps so I'm wondering if it is this that is causing the problem but other than that I'm totally baffled:-
      <mx:WindowedApplication
      xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="initprofile1NewsAndSportSO()"
      <mx:Script>
      <![CDATA[
      Bindable
      Embed(source="assets/images/bbcnews_small.png"
      public var
      image1:Class;
      Bindable
      Embed(source="assets/images/itv_small.png"
      public var
      image2:Class;
      Bindable
      Embed(source="assets/images/skynews_small.png"
      public var
      image3:Class;
      </mx:Script>
      <mx:Script>
      <![CDATA[
      import
      mx.collections.*;
      import
      flash.net.SharedObject;
      public var
      profile1NewsAndSportSO:SharedObject;
      private var profile1NewsAndSportaddLinksFullAC:ArrayCollection = new
      ArrayCollection([
      {link:
      "www.bbcnews.com", label:"BBC News", icon:"image1", largeImage:"assets/images/bbcnews_small.png", title:"BBC News", description:"BBC News description will go here"
      {link:
      "www.itv.com/", label:"ITV", icon:"image2", largeImage:"assets/images/itv_small.png", title:"ITV", description:"ITV Description will go here"
      {link:
      "www.skynews.com", label:"Sky News", icon:"image3", largeImage:"assets/images/skynews_small.png", title:"Sky News", description:"Sky News Description will go here"
      private var profile1NewsAndSportaddLinksAC:ArrayCollection = new
      ArrayCollection([
      {link:
      {link:
      {link:
      private function profile1NewsAndSportReset():void
      resetprofile1NewsAndSportAC();
      profile1NewsAndSportAddLinksTilelist.dataProvider
      = profile1NewsAndSportaddLinksAC;
      profile1NewsAndSportLinkChoice.dataProvider =
      new
      ArrayCollection([]);
      private function resetprofile1NewsAndSportAC():void
      profile1NewsAndSportaddLinksAC.removeAll();
      for each(var obj:Object in
      profile1NewsAndSportaddLinksFullAC){
      profile1NewsAndSportaddLinksAC.addItem(obj);
      private function initprofile1NewsAndSportSO():void
      profile1NewsAndSportSO = SharedObject.getLocal(
      "profile1NewsAndSport"
      if
      (profile1NewsAndSportSO.size > 0){
      if
      (profile1NewsAndSportSO.data.profile1NewsAndSportaddList){
      if(profile1NewsAndSportSO.data.profile1NewsAndSportaddList != "empty"
      var profile1NewsAndSportaddList:Array = profile1NewsAndSportSO.data.profile1NewsAndSportaddList.split(","
      var profile1NewsAndSporttempAC1:ArrayCollection = new
      ArrayCollection();
      for each(var str:String in
      for each(var obj1:Object in
      profile1NewsAndSportaddLinksAC){
      if
      (str == obj1.label){
      profile1NewsAndSporttempAC1.addItem(obj1);
      continue
      if
      (profile1NewsAndSporttempAC1.length > 0){
      profile1NewsAndSportAddLinksTilelist.dataProvider = profile1NewsAndSporttempAC1;
      if
      (profile1NewsAndSportSO.data.profile1NewsAndSportchoiceList){
      var profile1NewsAndSportchoiceList:Array = profile1NewsAndSportSO.data.profile1NewsAndSportchoiceList.split(","
      var profile1NewsAndSporttempAC2:ArrayCollection = new
      ArrayCollection();
      for each(var str2:String in
      for each(var obj2:Object in
      if
      (str2 == obj2.label){
      profile1NewsAndSporttempAC2.addItem(obj2);
      continue
      if
      (profile1NewsAndSporttempAC2.length > 0){
      profile1NewsAndSportLinkChoice.dataProvider = profile1NewsAndSporttempAC2;
      else
      profile1NewsAndSportReset();
      </mx:Script>
      <mx:TileList id="profile1NewsAndSportAddLinksTilelist" fontWeight="bold" dragEnabled="true" dragMoveEnabled="true" dropEnabled="true" height="292" width="650" left="21" columnCount="5" rowHeight="145" columnWidth="125" itemClick="titleLabel.text=profile1NewsAndSportAddLinksTilelist.selectedItem.title; websiteLinkLabel.text=profile1NewsAndSportAddLinksTilelist.selectedItem.link; descLabel.text=profile1NewsAndSportAddLinksTilelist.selectedItem.description; linkImage.source=profile1NewsAndSportAddLinksTilelist.selectedItem.largeImage;" itemDoubleClick="{navigateToURL(new URLRequest('http://' + profile1NewsAndSportAddLinksTilelist.selectedItem.link))}" doubleClickEnabled="true" backgroundColor="#000000" borderColor="#FFFFFF" color="#FFFFFF" borderSides="top right left" y="25"/>
      <mx:Canvas id="SitePreviewArea" y="10" width="453" height="540" backgroundColor="#545050" cornerRadius="20" borderStyle="solid" x="692" borderThickness="2" dropShadowEnabled="true" borderColor="#000000"
      <mx:Label x="45" y="309" text="Website Name:" width="150" height="52" fontSize="14" fontWeight="bold" color="#FFFFFF" left="10"/>
      <mx:Label x="150.5" y="309" id="titleLabel" width="282.5" height="24" fontWeight="bold" fontSize="14" color="#FCFF00"
      <mx:Label x="124.5" y="385" text="Website Description:" width="200" height="24" fontSize="14" fontWeight="bold" color="#FFFFFF" textAlign="center"/>
      <mx:TextArea x="16" y="417" id="descLabel" width="421" height="69" textAlign="left" color="#FCFF00" borderThickness="0" backgroundColor="#545050" editable="false" enabled="true" disabledColor="#FFFFFF" backgroundDisabledColor="#545050" fontWeight="bold" fontSize="12"
      <mx:Label x="61" y="342" text="Website Link:" width="150" height="52" fontSize="14" fontWeight="bold" color="#FFFFFF" left="10"
      <mx:TextArea x="150.5" y="343" id="websiteLinkLabel" width="282.5" height="33" fontWeight="bold" fontSize="12" color="#FCFF00" borderThickness="0" backgroundColor="#545050" editable="false" enabled="true" disabledColor="#FCFF00" backgroundDisabledColor="#545050"
      <mx:Button id="goToSiteButton" top="494" left="168" label="VISIT SITE" fontWeight="bold" fontSize="14" color="#000000" click="{navigateToURL(new URLRequest('http://' + websiteLinkLabel.text))}" fillAlphas="[1.0, 1.0]" fillColors="[#FFFFFF, #DCDCDC]" borderColor="#000000"
      <mx:Canvas x="99.5" y="51" width="250" height="250" backgroundColor="#FFFFFF"
      <mx:Image id="linkImage" click="{navigateToURL(new URLRequest('http://' + websiteLinkLabel.text))}" width="250" height="250" x="0" y="0" scaleContent="true" top="2" right="2" left="2" bottom="2"
      </mx:Canvas>
      </mx:Canvas>
      <mx:TileList id="profile1NewsAndSportLinkChoice" fontWeight="bold" dragEnabled="true" dragMoveEnabled="true" dropEnabled="true" height="292" width="650" left="21" columnCount="5" rowHeight="145" columnWidth="125" itemClick="titleLabel.text=profile1NewsAndSportLinkChoice.selectedItem.title; websiteLinkLabel.text=profile1NewsAndSportLinkChoice.selectedItem.link; descLabel.text=profile1NewsAndSportLinkChoice.selectedItem.description; linkImage.source=profile1NewsAndSportLinkChoice.selectedItem.largeImage;" itemDoubleClick="{navigateToURL(new URLRequest('http://' + profile1NewsAndSportLinkChoice.selectedItem.link))}" doubleClickEnabled="true" backgroundColor="#000000" borderColor="#FFFFFF" color="#FFFFFF" borderSides="top right left" y="325"
      </mx:WindowedApplication>
