1 Reply Latest reply on Aug 7, 2009 10:11 AM by Gregory Lafrance
    E4X maximum value
    Hessian0
      Hi
      I dont know how i can get the maximum or minimum value from an XML like this:
      <node>
          <subnode>
                <name>Jack</name>
                <age>21</age>
          </subnode>
      </node>
      <node>
          <subnode>
                <name>Maria</name>
                <age>55</age>
          </subnode>
          <subnode>
                <name>John</name>
                <age>37</age>
          </subnode>
      </node>
      I need to get maximum age attribute value using E4X syntax (in this case 55).
      Is that possible? Have you some ideas to solve my problem?
        • 1. Re: E4X maximum value
          Gregory Lafrance Level 6
          If this post answered your question or helped, please mark it as such.
          I don't know if you can do it purely with e4x, but this works:
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml">
            <mx:XML id="myData">
              <data>
                <node>
                  <subnode>
                    <name>Jack</name>
                    <age>21</age>
                  </subnode>
                </node>
                <node>
                  <subnode>
                    <name>Maria</name>
                    <age>55</age>
                  </subnode>
                  <subnode>
                    <name>John</name>
                    <age>37</age>
                  </subnode>
                </node>
              </data>
            </mx:XML>
            <mx:Script>
              <![CDATA[
                import mx.utils.ArrayUtil;
                private function getMax(xl:XMLList):uint{
                  var maxVal:uint = 0;
                  for each(var val:uint in xl){
                    maxVal = Math.max(maxVal, val);
                  return maxVal;
            </mx:Script>
            <mx:Text text="{getMax(myData..age)}"/>
          </mx:Application>
