8 Replies Latest reply on Aug 7, 2009 1:58 PM by Flex harUI
    blank screen for long time before preloader appears
    released87 Level 1
      I've been trying to disect the flex preloader to understand the load time. I have an application that shows a blank screen for quite some time before displaying the preloader. When the preloader does show it doesn't say 'Loading...' but skips straight to 'initializing' for a short time, then straight into the app.
      I am not sure what is going on and why it takes such a long time for the preloader to pop-up. i don't want visitors to think there is nothing there, because it says 'Done' in the bottom of the browser when it is blank; it could seem it is just a blank page to a visitor.
      can someone explain or point me in a direction where i can learn 1) when the 'preloader/loading' pops up 2) when 'initializing' pops up, and when the actual app loads. it seems it is skipping the first step, going straight to initiliazing for a short time and then loading the app.
      examples:
      www.encoemall.com
      demo.phourus.com
      better load time example:
      www.smartbizrecycling.com
      Jesse
        • 2. Re: blank screen for long time before preloader appears
          released87 Level 1
          I guess what I need to know is this:
          What exactly is loading before the flex preloader loads? when it is a blank screen is it loading 1) the entire swf (so blank screen duration would be directly proportional to the size of the swf) 2) the preinitiliaze/initialize phase
          here is my main app file:
          <mx:Application
          xmlns:mx="http://www.adobe.com/2006/mxml" preinitialize="loadUser()" layout="vertical" xmlns:progress="reseller.master.preloader.*" xmlns:master="reseller.master.*" width="100%" height="100%" xmlns:forms="reseller.master.forms.*"
          <mx:Script>
          <![CDATA[
          //Import
          import
          mx.controls.Alert;
          import
          flash.events.*;
          import
          flash.net.*;
          import
          mx.rpc.http.*;
          import
          mx.rpc.events.ResultEvent;
          import
          mx.managers.BrowserManager;
          import
          mx.managers.IBrowserManager;
          import
          mx.utils.URLUtil;
          //Objects
          public var variables:Object= new
          Object();
          private var
          browser:IBrowserManager;
          //Globals
          Bindable] public var
          global_ID:int;
          global_Email:String;
          global_Recipient:String;
          global_Company:String;
          global_Site:String;
          global_Style:String;
          global_Header:String;
          global_Directory:String;
          Bindable] public var global_Type:String= 'fdi_site'
          Bindable] public var global_Multi:Boolean= true
          title_Home:String;
          title_About:String;
          title_Blog:String;
          title_Contact:String;
          title_FDI:String;
          title_Multimedia:String;
          title_Store:String;
          disable_Header:String;
          disable_Menu:String;
          disable_Content:String;
          url_Header:String;
          url_Menu:String;
          url_Content:String;
          user_Username:String;
          background_Color:uint;
          primary_Color:uint;
          secondary_Color:uint;
          border_Color:uint;
          primary_Text:uint;
          secondary_Text:uint;
          Bindable] public var user_Admin:Boolean= false
          //Parameters
          private var
          _user:String;
          private function loadUser():void
          browser= BrowserManager.getInstance();
          browser.init(
          "", "Welcome!"
          parseURL();
          private function parseURL():void
          var fragment:Object = URLUtil.stringToObject(browser.fragment, "&"
          _user = fragment.user;
          if(global_Multi== false
          global_Directory=
          else
          global_Directory=
          'user/'+_user+'/'
          initPage();
          public function initPage():void
          var settingsRequest:HTTPService = new
          HTTPService();
          settingsRequest.url= global_Directory+
          "XML/settings.xml"
          settingsRequest.resultFormat=
          "e4x"
          settingsRequest.send(variables);
          settingsRequest.addEventListener(ResultEvent.RESULT, settingsLoaded);
          var contactRequest:HTTPService = new
          HTTPService();
          contactRequest.url= global_Directory+
          "XML/contact.xml"
          contactRequest.resultFormat=
          "e4x"
          contactRequest.send(variables);
          contactRequest.addEventListener(ResultEvent.RESULT, contactLoaded);
          public function settingsLoaded(event:ResultEvent):void
          var settingsXML:XML= event.result as
          XML;
          global_Company= settingsXML.company;
          global_Site= settingsXML.site;
          global_Header= settingsXML.header;
          //global_Style= "CSS/"+settingsXML.style+".swf";
          title_Home= settingsXML.homeTitle;
          title_About= settingsXML.aboutTitle;
          title_Blog= settingsXML.blogTitle;
          title_Contact= settingsXML.contactTitle;
          title_FDI= settingsXML.fdiTitle;
          title_Multimedia= settingsXML.multimediaTitle;
          title_Store= settingsXML.storeTitle;
          disable_Header= settingsXML.headerDisable;
          disable_Menu= settingsXML.menuDisable;
          disable_Content= settingsXML.contentDisable;
          url_Header= settingsXML.headerURL;
          url_Menu= settingsXML.menuURL;
          url_Content= settingsXML.contentURL;
          background_Color= settingsXML.background_Color;
          primary_Color= settingsXML.primary_Color;
          secondary_Color= settingsXML.secondary_Color;
          border_Color= settingsXML.border_Color;
          primary_Text= settingsXML.primary_Text;
          secondary_Text= settingsXML.secondary_Text;
          loadComplete();
          public function contactLoaded(event:ResultEvent):void
          var contactXML:XML= event.result as
          XML;
          global_Recipient= contactXML.recipient;
          private function loadStyle(style:String):void
          StyleManager.loadStyleDeclarations(style);
          private function loadComplete():void
          if(disable_Header== "true"
          header.visible=
          false
          text_header.htmlText= global_Header;
          var application:CSSStyleDeclaration= StyleManager.getStyleDeclaration('Application'
          application.setStyle(
          'backgroundColor'
          , background_Color);
          'themeColor'
          , primary_Color);
          var linkButton:CSSStyleDeclaration= StyleManager.getStyleDeclaration('LinkButton'
          linkButton.setStyle(
          'color'
          , primary_Text);
          'textRollOverColor'
          , secondary_Text);
          'rollOverColor'
          , primary_Text);
          //loadStyle(global_Style);
          current_master.selectedChild= master_main;
          </mx:Script>
          <mx:Style>
          Application
          backgroundGradientColors: #666666, #333333
          backgroundGradientAlphas: 0.04, 0.21
          color: #222222
          .box
          borderStyle: solid
          cornerRadius: 5
          backgroundColor: #eeeeee
          backgroundAlpha: 1
          padding-top: 10px
          padding-right: 10px
          padding-left: 10px
          padding-bottom: 10px
          LinkButton
          font-size: 11px
          RichTextEditor
          borderColor: #fefefe
          borderAlpha: 1
          highlightAlphas: 0.32, 0.1
          headerColors: #dddddd, #cccccc
          titleStyleName: "mypanelTitle"
          Alert
          borderAlpha: 1
          backgroundColor: #ffffff
          color: #000000
          .mypanelTitle
          font-weight:bold
          ApplicationControlBar
          highlightAlphas: 0.2, 0.16
          fillAlphas: 0, 0
          dropShadowEnabled: true
          TextInput
          color: #000000
          borderColor: #000000
          Button
          fillAlphas: 1, 1
          color: #000000
          textRollOverColor: #333333
          .copyright
          color: #000000
          ComboBox
          color: #000000
          borderColor: #ffffff
          iconColor: #000000
          highlightAlphas: 0.16, 0.28
          fillAlphas: 1, 1, 0, 0
          fillColors: #ffffff, #cccccc, #ffffff, #eeeeee
          arrowButtonWidth: 22
          backgroundAlpha: 1
          selectionColor: #ffffff
          textSelectedColor: #333333
          useRollOver: true
          themeColor: #000000
          alternatingItemColors: #ffffff, #cccccc
          dropdownStyleName: "myComboBoxDropDowns"
          .myComboBoxDropDowns
          borderThickness: 0
          DataGrid
          color: #000000
          .play
          skin: Embed(source="Icons/Play_Normal.png"
          over-skin: Embed(source="Icons/Play_Over.png"
          .pause
          skin: Embed(source="Icons/Pause_Normal.png"
          over-skin: Embed(source="Icons/Pause_Over.png"
          .stop
          skin: Embed(source="Icons/Stop_Normal.png"
          over-skin: Embed(source="Icons/Stop_Over.png"
          .previous
          skin: Embed(source="Icons/Previous_Normal.png"
          over-skin: Embed(source="Icons/Previous_Over.png"
          .next
          skin: Embed(source="Icons/Next_Normal.png"
          over-skin: Embed(source="Icons/Next_Over.png"
          </mx:Style>
          <mx:Canvas width="850" height="150" backgroundImage="{url_Header}"
          <progress:Progress id="progress"
          <mx:ApplicationControlBar id="header" width="850" height="150" paddingBottom="0" x="0" y="0" backgroundColor="{primary_Color}"
          <mx:Text id="text_header" fontSize="18" fontWeight="bold" textAlign="left" x="25" y="25"
          <forms:Authorize id="form_login" x="550" y="10"
          </mx:Canvas>
          <mx:Box id="container_main" horizontalAlign="center" width="100%" height="100%"
          <mx:ViewStack id="current_master"
          <mx:Box id="master_init"
          </mx:Box>
          <mx:Box id="master_main"
          <master:Main id="Main_Section"
          </mx:Box>
          <mx:Box id="master_editor"
          <master:Editor
          </mx:Box>
          </mx:ViewStack>
          </mx:Box>
          <mx:Label styleName="copyright" text="Copyright 2009 {global_Company}. All rights reserved."
          <mx:Text styleName="copyright"
          <mx:htmlText>
          <![CDATA[
          <p align="center"><i>Site Designed by <a href="http://www.quick-sites.biz" target="_blank">Jesse Drelick</a>.</i></p>
          </mx:htmlText>
          </mx:Text>
          Do you think it has something to do with the Browser Manager or the preinitialize?
          • 3. Re: blank screen for long time before preloader appears
            Flex harUI Adobe Employee
            Flex SWFs are two-frame SWFs  The preloader is the first frame, the app is the second frame.  As soon as the bytes of the first frame are downloaded, the preloader shows up and the rest of the SWF downloads then the app is initialized.
            If you are using "#" in the URL, you might be hitting this bug: https://bugs.adobe.com/jira/browse/FP-2332
            Otherwise, if you're using a custom preloader, make sure it doesn't drag lots of code into the first frame.
            Also try your app using a non-debugger player.
            Alex Harui
            Flex SDK Developer
            Adobe Systems Inc.
            Blog: http://blogs.adobe.com/aharui
            • 4. Re: blank screen for long time before preloader appears
              released87 Level 1
              so the preloader should be loaded before the rest of the .swf? this would mean it should be a relatively standard load time when using the standard preloader, considering the preloader loads first, then the 2nd frame is loaded. it seems like the first frame is taking much longer to load
              if using the standard flex preloader, should the blank screen be the same duration regardless of .swf size? so if i have a 10 mb swf it will take the same time until the preloader shows up from the blank screen, but will take much longer to get to the app when the preloader is showing?
              i tried the # issue, not sure if it made a difference, though i wouldn't be surprised if the Browser Manager has something to do with it.
              thanks for your help
              • 5. Re: blank screen for long time before preloader appears
                released87 Level 1
                it seems .swf size has no effect on the blank screen duration, as you have mentioned. i have embedded a large file making the file size 3.5mb instaed of 350kb, and the blank screen duration was the same, though the 'loading' phase of the preloader was much longer, as expected. so apparently the file size is not the culprit (considering i have a small file size anyway it really wouldn't make sense for that duration)
                i am now curious if the browser manager is part of the problem as you have mentioned about the #, otherwise i can't think of anything else
                • 6. Re: blank screen for long time before preloader appears
                  If your URL you used to start the app doesn't have a # in it, then that problem is not affecting you, even if you use BrowserManager in your app and later URLs have #
                  Can you post your SWF?  It doesn’t have to run.  I'll just download it and see how big frame1 is.
                  Alex Harui
                  Flex SDK Developer
                  Adobe Systems Inc.
                  • 7. Re: blank screen for long time before preloader appears
                    released87 Level 1
                    i have attached the .swf (note i use a rsl for the flex framework) anyway i have it setup so if a user goes to http://professional.phourus.com/user/phourus, a php script uses header('Location: http://professional.phourus.com/index.html#user=phourus') to load the user's page, as sort of an alias.
                    You can try both of those urls...
                    thank you for your help
                    • 8. Re: blank screen for long time before preloader appears
                      This url: http://professional.phourus.com/index.html#user=phourus has the '#' in it, so you are definitely going to experience the dead-air problem I mentioned earlier.  It did load quickly for me though.
                      Alex Harui
                      Flex SDK Developer
                      Adobe Systems Inc.
