When a process is started, there is a Task Details tab that shows up beside the form tab. I am trying to remove it with a custom UI, but when I remove the tab from lc > endpoint > EndpointDetailsSelector.mxml the form will no longer load when I start the process. Instead, it will initially load only if I go to the attachments tab and then back to the form tab again. I can get it to work if I have the attachments tab load where the task details tab originally did, but I do not want the attachments tab showing up first in the list of tabs. Does anyone know what might be causing the form not to load? Or, is it possible to rearrange the tabs once the tabs have already been loaded? Thanks for your help.
Views
Total Likes
