6 Replies Latest reply on Aug 8, 2009 9:46 AM by Jacob Bugge
    Shapes with curved sides
    Karl- Level 1
      I think I might be (hopefully) working too hard....
      I know I can draw a triangle with the polygon tool. But I want the sides of my triangle to be curved (both concaved and convex). Is their an easy way to achieve this?  Or do I have to use the arc tool?  (I also need a pin cushion shape. So hopefully the same technique works with the rectangle tool too?)
      (Or if I have to use the arc tool and draw individual lines, is there a tool in Photoshop or Fireworks that would make this easier?)
      TIA.
        • 1. Re: Shapes with curved sides
          Jacob Bugge MVP & Adobe Community Professional
          Karl,
          The pin cushion shape may be created using the Effect>Warp>Bulge with negative value, first horizontally then vertically, or in reverse order. Positive value for actual bulging.
          Bulge does not work as nicely with a triangle. Maybe new options have emerged since 10.
          • 2. Re: Shapes with curved sides
            Karl- Level 1
            Found what I (at least) need....
            Object -> Envelope Distort -> Make with Warp
            • 3. Re: Shapes with curved sides
              PrepressPro1 Adobe Community Professional
              On the Triangle try the Warp>Inflate and use a neg. number.
              • 4. Re: Shapes with curved sides
                As far as I can see, all options result in different curvatures for horizontal/vertical and slanting sides, at least in 10, so that it will look funny for a triangle even if you use different valus for horizontal and vertical bend/whatever, including different curvatures at either end of slanting lines.
                Has that changed?
                • 5. Re: Shapes with curved sides
                  JETalmage Level 6
                  To find the centroid (geometric center) of a triangle (or any other path, for that matter):
                  1. Copy.
                  2. Paste In Front.
                  3. Object>Path>Average.
                  4. Snap a horizontal and a vertical Ruler Guide to the position of the points.
                  5. Delete.
                  6.Use the intersection of the two Guides as the center of scale transformations on the points and/or the handles (Object>Select>Handles).
                  Here's a method for making your bulging triangle using Transform Effect:
                  After step 7, an alternative way to join the figure into one path is: Expand Appearance, Ungroup, Divide Pathfinder. (The Pathfinder will stupidly remove the fill and stroke.)
                  JET
                  • 6. Re: Shapes with curved sides
                    James,
                    When will step 7 be released?
                    Edit: It appeared when I had posted, after being invisible. Strange.
