8 Replies Latest reply on Aug 4, 2008 8:09 AM by Newsgroup_User
    Using a Variable for dataProvider Information
    Kurrykid Level 3
      I am trying to use a variable to populate the dataProvider for printing. I have pulled the example from the Flex 3: Training from the source book. When I try to use a variable, I get a Flash Player error stating that the provider is undefined. Does anyone know the correct way to type this so that it works?
      Here's the code:
      private function doPrint(event:Event):void{
      selection = event.currentTarget.id+"s.dataProvider"
      var pj:FlexPrintJob = new FlexPrintJob();
      if(pj.start() != true)
      return;
      var myPrintView:PrintView=new PrintView();
      this.addChild(myPrintView);
      myPrintView.myPrintDG.showHeaders = false;
      myPrintView.myPrintDG.rowHeight = 18;
      myPrintView.contact.text = "User Name: " + uname;
      myPrintView.myPrintDG.dataProvider = "(selection)";
      pj.addObject(myPrintView);
      pj.send();
      removeChild(myPrintView);
      This line is the line I need to work: myPrintView.myPrintDG.dataProvider = "(selection)";
      If I replace "(selection)" with roles.dataProvider it works fine. I think it is just a syntax issue. If you look at the line above, I am using a variable for the User Name and that works fine.
      Any help would be greatly appreciated.
      Dave
