0 Replies Latest reply on Aug 7, 2009 3:16 PM by Jason Szeto
    [svn:fx-trunk] 9182: PopUpAnchor bug fixes
    Jason Szeto Level 3
      Revision: 9182
      Author:   jszeto@adobe.com
      Date:     2009-08-07 15:16:18 -0700 (Fri, 07 Aug 2009)
      Log Message:
      http://bugs.adobe.com/jira/browse/SDK-22425 - Opening a DropDownList that is in a child application from a different domain from the parent causes a RTE
      PopUpAnchor references the stage for some fullScreenMode logic. The fix is to put a try/catch around this code. If we are in a subapplication, accessing the stage?\226?\128?\153s displayState property is a security violation. It is not a critical calculation, so it is alright if it isn?\226?\128?\153t run.
      Fixing the RTE exposed a different bug involving what transforms to apply to the popUp. The original code was applying the concatenatedMatrix of the PopUpAnchor to the popUp. However, when the PopUpAnchor is in a sub application in a different domain, then the popUp is parented by a systemManager that is a child of the main application. This resulted in concatenated transforms applied to the sub application getting applied twice. The fix is to get the concatenated transform from the popUp?\226?\128?\153s parent to the PopUpAnchor. I get this transform by taking the concatenated transform and subtracting out the popUp parent?\226?\128?\153s concatenated transform.
      QE notes: Add tests for subapplication/module use cases
      Doc notes: None
      Bugs: SDK-22425
      Reviewer: Alex
      Tests run: DropDownList, PopUpAnchor
      Is noteworthy for integration: No
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/PopUpAnchor.as
