0 Replies Latest reply on Aug 7, 2009 3:26 PM by Jason Szeto
    [svn:fx-trunk] 9183: Transform matrix bug fix
    Jason Szeto Level 3
      Revision: 9183
      Author:   jszeto@adobe.com
      Date:     2009-08-07 15:25:44 -0700 (Fri, 07 Aug 2009)
      Log Message:
      http://bugs.adobe.com/jira/browse/SDK-22390 - Color transform is incorrectly applied in MXML Graphics
      For a component or graphic, specifying a transform without an explicit matrix declaration was overriding the convenience transform properties.
      The new behavior is to only apply the transform?\226?\128?\153s matrix to the component or graphic if it was explicitly specified.
      QE notes: Add test case
      Doc notes: Explain that transform matrix will only apply if explicitly set
      Bugs: SDK-22390
      Reviewer: Glenn
      Tests run: spark primitives
      Is noteworthy for integration: No
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/geom/Transform.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/GraphicEleme nt.as
