15 Replies Latest reply on Dec 12, 2009 1:15 PM by Scott Osborn
    System Crash on HD Export
    Scott Osborn
      Searched the forums (here and elsewhere) and couldn't find anyone else having this particular problem:  When I export to HD (to either MPEG2 or H.264)my system will crash and reboot.  (This isn't just AME crashing, it's the entire system.)
      In the hopes that someone can spot what I'm doing wrong, here's the details:
      1) Windows 64-bit Vista, Home Premium Version.  8 Gigs of RAM.  Hard drive space out the wazoo.  NVidia GeForce 8800 GTS w/ 640 MB of VRAM.
      Running Premiere Pro CS4 4.1.0.
      2) Shot the video using a Sony HDR-V1U in HD.
      3) For the first pass, I digitized and editted the footage in SD (used the camera's downconverting mode).  Turned on "automatic scene detection" so that I didn't have one big file.
      4) Editted all the footage from #3 until we were all happy.  Exports fine, to DVD, whatever.
      5) Converted it to HD:  I logged all the times from the SD clips, then captured the tape again, this time in HD (turned off the camera's downconverting mode).  (ie., I now had duplicates of the SD clips in HD.)
      6) Created a new sequence (HDV 1080 24p).  Copied all the SD clips from the final, editted SD timeline into the new sequence.  Saved the project with a new name (ie, tacked "HD" on the end).
      7) Using the "replace footage" command, I replaced the captured SD clips with the captured HD clips.  As the clips were replaced, the timeline's SD clips were automatically replaced by the HD clips, saving us from having to recut everything in HD.
      The rest is pretty straightforward:  Go to Export->Media...  Select either MPEG2 or H.264.  Start Media Exporter.  Start the encoding.  Wait a minute or two, boom.
      A.  Has anyone else had this particular problem?  If so, how did you solve it?
      B.  Looking over my hardware specs, is there anything that could lead to such a crash, ya think?  Notice that I don't have a RAID array:  Could this be the source of my problems?
      C.  Looking over my methodology (ie., working in SD, then replacing the footage), is there anything there that could lead to such a crash?  Am I the only person who works this way?
      In advance, thanks for the input.
      Scott Osborn
        • 1. Re: System Crash on HD Export
          Jeff Bellune Level 5
          System shutdowns when rendering are usually hardware related.  Often
          they are heat induced.  But even if it's not a case of just overheating,
          you need to realize that rendering taxes your entire system to the
          limit.  Any weak components or drivers will fail under these conditions
          even though they may operate perfectly well for more ordinary tasks like
          web surfing, email or office work.
          To help troubleshoot, you need to stop the automatic restart of the
          system so that you can see a screen that will enumerate the cause of the
          failure.  To do that, go to Computer | System Properties | Advanced
          System Settings.  Click on the Settings button under Startup and
          Recovery. Under System Failure, uncheck Automatically Restart.
          The next time you have a system failure, you'll be presented with a
          screen that contains information about the failure.
          -Jeff
          • 2. Re: System Crash on HD Export
            Scott Osborn Level 1
            Hi Jeff,
            Thanks for the input, I'm sure you're correct about this being hardware-related.  Now if I can just decipher the system logs, I'll know which module is the suspect.
            Scott
            • 3. Re: System Crash on HD Export
              With a complete system shutdown and restart, you may not get any
              information from the system logs because Windows wouldn't have a chance
              to write to the log files.
              Changing the system failure options as described is still your best bet.
              -Jeff
              • 4. Re: System Crash on HD Export
                Harm Millaard Level 7
                Scott,
                While I completely agree with Jeff on the hardware side of things, the second link in the link below is oriented to system crashes and BSOD situations. You could try some of the suggestions there.
                Some suggestions
                • 5. Re: System Crash on HD Export
                  You described your process... now describe your hardware... in DETAIL
                  Brand/Model computer and/or motherboard
                  Ditto for CPU... AND what is your cooling... stock, or replacement cooling tower
                  Ditto for case, including a list of all case fans
                  When was the last time you opened the case and blew out the dust bunnies?
                  When you go to the system monitor in control panel, what is your current CPU temp?
                  (note that you may need to search to find this information... may not be called "system monitor")
                  How is your case "set" and are any of the fan openings in any way blocked
                  Do you have a different power supply you may install as a test?
                  • 6. Re: System Crash on HD Export
                    Bill Gehrke Adobe Community Professional & MVP
                    Any good definitions of what this equates too?
                    • 7. Re: System Crash on HD Export
                      Hmm... I work at Washington State University, which is sometimes call "Wazoo" but I've never seen anything in any of the WSU publications about how that would equate to anything involving a computer
                      • 8. Re: System Crash on HD Export
                        Bill & John,
                        > Any good definitions of what this ["out the wazoo"] equates too?
                        Sorry for the confusion.  This is a highly technical term for "a large amount".  <G>
                        [And, FWIW, in this case the project (and render-to) drive is 465 gigs, with 157 gigs free.  The root drive has 225 gigs free.]
                        Scott
                        • 9. Re: System Crash on HD Export
                          Jeff,
                          1) As it turns out, Windows did manage to log a Premiere crash event.  It's unclear from it, though, what the offending module is.
                          2) Yes.  I tried this and now when it crashes, the screen goes black, with a blinking cursor.  <Sigh>
                          After some testing, I've eliminated the hard drive and am narrowing my focus to:
                          1) Bad memory chip or
                          2) Ancient sound card
                          Thanks again for the input!
                          Scott
                          • 10. Re: System Crash on HD Export
                            Harm,
                            Thanks for the link.  I'm walking through the details at http://kb2.adobe.com/cps/405/kb405950.html right now, hoping for the best.
                            Scott
                            • 11. Re: System Crash on HD Export
                              John,
                              ZT brand, the motherboard is unknown (though it's been replaced).
                              > Ditto for CPU...
                              AMD phenom 9500 quad core
                              Couldn't tell you.
                              About 2 months ago.
                              Hmm.  Couldn't find this.
                              Could be wrong, obviously, but I don't think this is a heating issue:  I got these same symptoms after it cooled all night.
                              Huh.  I had to replace the one that it (the PC) came with when I upgraded to the NVidia card.  So, no, I don't have a different power supply.  But I'll put that on my "test for this" list...
                              Scott
                              • 12. Re: System Crash on HD Export
                                [Meant to come back sooner and report these findings for posterity...]
                                Turns out that Jeff was correct when he said:
                                "System shutdowns when rendering are usually hardware related."
                                I had an old (7+ years) Audigy soundcard that Vista complained about when I installed it.  Replaced it with a near-new X-Fi and have been rendering without difficulties since.
                                Again, thanks to all the helpful souls who chimed in!
                                Scott
                                • 13. Re: System Crash on HD Export
                                  And thank you for posting back with your solution.
                                  -Jeff
                                  • 14. Re: System Crash on HD Export
                                    [Just when you thought it was fixed...]
                                    Last time I posted in this forum, I identified the aged Audigy sound card as the culprit.  After a couple of months, BLAM, the same system-reboots-when-rendering-HD problem reappeared.
                                    The other hypothesis offered in this forum was overheating.  So, disgusted, I installed SpeedFan (http://www.almico.com/speedfan.php) and sure enough, my CPU was operating in the Red Flames of Death zone.  3 Zalman case fans and a new CPU heatsink later, and we're running in the green, and no, NO system-rebooting problems.  Been verifying this over the last month, so Yep, overheating was the problem, case fans and heatsink were the solution.
                                    Thanks again for all the help!
                                    Scott
                                    • 15. Re: System Crash on HD Export
                                      I had a CPU fan fail once... and my system would only run for 5-6 minutes before it would die
                                      New fan and it's been working ever since... and video rendering STILL makes all the variable speed fans run at top speed
