18 Replies Latest reply on Aug 12, 2009 7:37 AM by kglad
    load image
    itgate.ir
      hi
      please see this xml code
      <gallary>
          <icon iconUrl="images/1.png" xpos="150" ypos="100"></icon>
          <icon iconUrl="images/2.png" xpos="190" ypos="150"></icon>
      </gallary>
      then ;
      i want to load per iconUrl in the xpos and ypos , by the following code
      var myXml:XML = new XML();
      myXml.ignoreWhite = true;
      myXml.load("config.xml");
      myXml.onLoad = function(success) {
          for(i=0 ; i<=myXml.childNodes.length ;i++){
                  loader = this.firstChild.childNodes[i].attributes.iconUrl;
                  _root.createEmptyMovieClip("al",10);
      al.loadMovie(loader);
      al._x=this.firstChild.childNodes[i].attributes.xpos;
      al._y=this.firstChild.childNodes[i].attributes.ypos;
      this code load correct the latest iconUrl in xml file to specific position but the problem is , the other images is not load or maybe unload because the name of the movie clip that would be load the image is not different .
      my question is :
      what can i do rename the movie clip dynamically ?
      best regards .
        • 1. Re: load image
          you're replacing your target movieclips by using the same depth.  try:
          itgate.ir wrote:
          hi
          <gallary>
          </gallary>
          then ;
                     var targetMC:MovieClip = _root.createEmptyMovieClip("al"+i,10+i);
                      _root.targetMC.loadMovie(loader);
                      _root.targetMC._x=this.firstChild.childNodes[i].attributes.xpos;
                      _root.targetMC._y=this.firstChild.childNodes[i].attributes.ypos;
          my question is :
          best regards .
          • 2. Re: load image
            itgate.ir Level 1
            thanks
            but not work yet
            becuase the first parameters of createEmptyMovieClip is string and not suport the variables .
            • 3. Re: load image
              your last post doesn't make sense.
              copy and paste your corrected code.
              • 4. Re: load image
                itgate.ir Level 1
                excuse me
                can you see this file please
                http://rapidshare.com/files/265665494/load_icon.rar.html
                i replace your code , but not work
                • 5. Re: load image
                  i generally don't download and correct files unless i'm hired to do that.  i don't believe that should be needed in your situation.  post your code.
                  • 6. Re: load image
                    itgate.ir Level 1
                    excuse me for sending the file , i don't know .
                    the code :
                    • 7. Re: load image
                      copy and paste the trace output from:
                          for (i=0; i<=myXml.childNodes.length; i++) {
                              var targetMC:MovieClip = _root.createEmptyMovieClip("al"+i, 10+i);
                              trace(_root.targetMC+": "+loader);
                              _root.targetMC._x = this.firstChild.childNodes[i].attributes.xpos;
                              _root.targetMC._y = this.firstChild.childNodes[i].attributes.ypos;
                      • 8. Re: load image
                        itgate.ir Level 1
                        output :
                        undefined: images/1.png
                        undefined: images/2.png
                        • 9. Re: load image
                          what flash player version are you publishing for?
                          • 10. Re: load image
                            itgate.ir Level 1
                            flash player 10
                            • 11. Re: load image
                              that should be:
                              • 12. Re: load image
                                itgate.ir Level 1
                                thanks
                                it's work very well by this code
                                can you tell me what the last prolbems ?
                                • 13. Re: load image
                                  i used _root.targetMC when i should have used targetMC
                                  • 14. Re: load image
                                    itgate.ir Level 1
                                    thanks a lot
                                    if it's not a problem , i am a new question .
                                    i want to set an event or link per moviclip ,can you tell me what i do ?
                                    • 15. Re: load image
                                      you should start a new thread explaining what you want.  for example, you might want your movieclip to open a html file when it's clicked.
                                      • 16. Re: load image
                                        itgate.ir Level 1
                                        yes
                                        i want clicked the icons , then run the html address that write in the xml file .
                                        • 17. Re: load image
                                          itgate.ir Level 1
                                          i add this code for linked the icons to the address page , but not work
                                          t=this.firstChild.childNodes[i].attributes.pageAddress;
                                          targetMC.onMouseDown=function(){
                                                getURL(t,"_blank");
                                          can you help me ?
                                          • 18. Re: load image
                                            start a new thread.
