4 Replies Latest reply on Aug 10, 2009 8:43 AM by nikos101
    Get object by id
    nikos101 Level 2
      If I have an object that is not a child of anything in my application, how do I get it with just its id name?
        • 1. Re: Get object by id
          sirk214
          I don t know, if that s the best solution, but you can try this:
          Make a reference in your Main Application YourApp:
          public var myObject:Object;
          If you create your Object, use your Object from the Main Aplication
          YourApp(ComponentYouCreateYourObject.parentApplication).myObject = new Object();
          Actually, you shouldn't need the id anymore, because you are able to acces the object with this cast:
          K
          • 2. Re: Get object by id
            nikos101 Level 2
            Well the trouble is that I need to use the id parameter as I have a pool of objects and I don't want to repeate code. Basically someone clicks on a button and that particular button passed the id of the object I need as a string to a function
            • 3. Re: Get object by id
              Gregory Lafrance Level 6
              I don't fully understand the problem, but if the issue is accessing a variable using a string, you may try this:
              this[objectIDString]
              If this post answers your question or helps, please mark it as such.
              • 4. Re: Get object by id
                nikos101 Level 2
                wow it was that easy, thanks mate
